[postgis-tickets] [PostGIS] #4739: st_dwithin : no spatial operator found
trac at osgeo.org
Fri Oct 2 07:32:29 PDT 2020
Reporter: grantfin | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by Algunenano):
Hi ansel, thanks a lot for the detailed explanation.
Using that, it became pretty clear what the issue was: the index support
function (postgis_index_supportfn) needs to know the oid of the internal
types (they aren't constant) and to do that it uses postgis_oid.
postgis_oid either knows the types already because we have initialized the
internal cache or it uses TypenameGetTypid, which only look up the types
inside the current search_path.
The solution is to make sure we initialize the internal cache at the start
of postgis_index_supportfn.
The initial patch that fixes it is here:
https://github.com/postgis/postgis/pull/581 But I'm going to review what
other functions might end up using the cache and ensure it's always
initialized.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4739#comment:3>
