[postgis-tickets] [PostGIS] #4739: st_dwithin : no spatial operator found
PostGIS trac at osgeo.org
Fri Oct 2 07:59:26 PDT 2020
  Reporter:  grantfin  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.1.0
 Component:  postgis   |    Version:  3.0.x
Resolution:            |   Keywords:
Comment (by Algunenano):
 I've found and fixed some other functions that are affected by the same
 issue, as they relied on being able to do the dynamic lookup (which only
 works when the types are available in the search_path).
 This is a similar issue as #4661.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4739#comment:4>
