[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-77-g678f526
Mon Oct 5 02:28:14 PDT 2020
the project "PostGIS".
       via  678f526670b6b1805495431e62f12072bb9485cf (commit)
      from  76b524544ccbaab6831f672ef1c56dd23d925996 (commit)
revisions in full, below.
commit 678f526670b6b1805495431e62f12072bb9485cf
Author: Raúl Marín <git at rmr.ninja>
Date:   Fri Oct 2 16:09:45 2020 +0200
    Ensure all functions using postgis_oid initialize the internal cache
    References #4739
    Closes https://github.com/postgis/postgis/pull/581
diff --git a/NEWS b/NEWS
index cb49fbb..c5eec4e 100644
--- a/NEWS
+++ b/NEWS
@@ -43,6 +43,7 @@ Only tickets not included in 3.1.0alpha2
     malformed WKB. Remove memory leaks in malformed WKB cases. (Paul Ramsey)
   - #4740, Round values in geography_distance_tree
            as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina Obe)
+  - #4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index 56d0ab6..b5202d7 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -2300,6 +2300,9 @@ Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
 	bool only_parent = false;
 	int key_type;
+	/* We need to initialize the internal cache to access it later via postgis_oid() */
+	postgis_initialize_cache(fcinfo);
 	if ( PG_NARGS() == 4 )
 		nsp = text_to_cstring(PG_GETARG_TEXT_P(0));
@@ -2562,8 +2565,12 @@ Datum _postgis_gserialized_index_extent(PG_FUNCTION_ARGS)
 	int key_type;
 	Oid tbl_oid = PG_GETARG_DATUM(0);
 	text *col = PG_GETARG_TEXT_P(1);
+	Oid idx_oid;
-	Oid idx_oid = table_get_spatial_index(tbl_oid, col, &key_type);
+	idx_oid = table_get_spatial_index(tbl_oid, col, &key_type);
 	if (!idx_oid)
 		PG_RETURN_NULL();
diff --git a/postgis/gserialized_spgist_2d.c b/postgis/gserialized_spgist_2d.c
index fc60e18..3957075 100644
--- a/postgis/gserialized_spgist_2d.c
+++ b/postgis/gserialized_spgist_2d.c
@@ -291,6 +291,7 @@ PGDLLEXPORT Datum gserialized_spgist_config_2d(PG_FUNCTION_ARGS)
 	spgConfigOut *cfg = (spgConfigOut *)PG_GETARG_POINTER(1);
 	Oid boxoid = InvalidOid;
 	boxoid = postgis_oid(BOX2DFOID);
diff --git a/postgis/gserialized_spgist_3d.c b/postgis/gserialized_spgist_3d.c
index b417baa..61953fa 100644
--- a/postgis/gserialized_spgist_3d.c
+++ b/postgis/gserialized_spgist_3d.c
@@ -374,6 +374,7 @@ PGDLLEXPORT Datum gserialized_spgist_config_3d(PG_FUNCTION_ARGS)
 	boxoid = postgis_oid(BOX3DOID);
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index d783337..ce53816 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -279,6 +279,12 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
 	Node *rawreq = (Node *) PG_GETARG_POINTER(0);
 	Node *ret = NULL;
+	/* The support function need the cache to be populated to know what the type Oids are.
+	 * Otherwise it will need look them up dynamically, which only works in the schema where Postgis
+	 * is installed is part of the search path (Trac #4739)
 	if (IsA(rawreq, SupportRequestSelectivity))
 		SupportRequestSelectivity *req = (SupportRequestSelectivity *) rawreq;
diff --git a/postgis/lwgeom_out_geobuf.c b/postgis/lwgeom_out_geobuf.c
index e70f7f4..b8bc61e 100644
--- a/postgis/lwgeom_out_geobuf.c
+++ b/postgis/lwgeom_out_geobuf.c
@@ -52,6 +52,9 @@ Datum pgis_asgeobuf_transfn(PG_FUNCTION_ARGS)
 	MemoryContext aggcontext;
 	struct geobuf_agg_context *ctx;
 	if (!AggCheckCallContext(fcinfo, &aggcontext))
 		elog(ERROR, "pgis_asgeobuf_transfn: called in non-aggregate context");
 	MemoryContextSwitchTo(aggcontext);
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 0c24319..b1e6948 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -93,6 +93,7 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
 	Oid geom_oid = InvalidOid;
 	Oid geog_oid = InvalidOid;
 	geom_oid = postgis_oid(GEOMETRYOID);
 	geog_oid = postgis_oid(GEOGRAPHYOID);
diff --git a/postgis/lwgeom_out_mvt.c b/postgis/lwgeom_out_mvt.c
index 27efd3e..e4e71e5 100644
--- a/postgis/lwgeom_out_mvt.c
+++ b/postgis/lwgeom_out_mvt.c
@@ -132,6 +132,9 @@ Datum pgis_asmvt_transfn(PG_FUNCTION_ARGS)
 	MemoryContext aggcontext, old_context;
 	mvt_agg_context *ctx;
 		elog(ERROR, "%s called in non-aggregate context", __func__);
Summary of changes:
 NEWS                            | 1 +
 postgis/gserialized_estimate.c  | 9 ++++++++-
 postgis/gserialized_spgist_2d.c | 1 +
 postgis/gserialized_spgist_3d.c | 1 +
 postgis/gserialized_supportfn.c | 6 ++++++
 postgis/lwgeom_out_geobuf.c     | 3 +++
 postgis/lwgeom_out_geojson.c    | 1 +
 postgis/lwgeom_out_mvt.c        | 3 +++
 8 files changed, 24 insertions(+), 1 deletion(-)
hooks/post-receive
