[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.2-9-gcb66c8b
git at osgeo.org
git at osgeo.org
Mon Oct 5 02:29:04 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
via cb66c8b17428944dfccb5622db65ae3d52b19a07 (commit)
from f078f3d0ec0345233f33e5b005d979460b12810e (commit)
revisions in full, below.
commit cb66c8b17428944dfccb5622db65ae3d52b19a07
Author: Raúl Marín <git at rmr.ninja>
Date: Fri Oct 2 16:09:45 2020 +0200
Ensure all functions using postgis_oid initialize the internal cache
Closes #4739
diff --git a/NEWS b/NEWS
index c10662b..5350f53 100644
--- a/NEWS
+++ b/NEWS
@@ -1,10 +1,12 @@
PostGIS 3.0.3dev
2020/xx/xx
* Bug Fixes and Enhancements *
- #4742 tiger geocoder reverted to 2018 version on tiger upgrade
- #4757, Handle line collapse due to snap-to-existing node (Sandro Santilli)
- - #4719, Fail fast when srids don't match ST_Intersection(geometry,raster)
+ - #4719, Fail fast when srids don't match ST_Intersection(geometry,raster)
Also schema qualify calls in function. (Regina Obe)
+ - #4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)
PostGIS 3.0.2
2020/08/15
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index fa4700e..6f55494 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -2303,6 +2303,9 @@ Datum gserialized_estimated_extent(PG_FUNCTION_ARGS)
bool only_parent = false;
int key_type;
+ /* We need to initialize the internal cache to access it later via postgis_oid() */
+ postgis_initialize_cache(fcinfo);
if ( PG_NARGS() == 4 )
nsp = text_to_cstring(PG_GETARG_TEXT_P(0));
@@ -2565,8 +2568,12 @@ Datum _postgis_gserialized_index_extent(PG_FUNCTION_ARGS)
int key_type;
Oid tbl_oid = PG_GETARG_DATUM(0);
text *col = PG_GETARG_TEXT_P(1);
+ Oid idx_oid;
- Oid idx_oid = table_get_spatial_index(tbl_oid, col, &key_type);
+ idx_oid = table_get_spatial_index(tbl_oid, col, &key_type);
if (!idx_oid)
PG_RETURN_NULL();
diff --git a/postgis/gserialized_spgist_2d.c b/postgis/gserialized_spgist_2d.c
index fc60e18..3957075 100644
--- a/postgis/gserialized_spgist_2d.c
+++ b/postgis/gserialized_spgist_2d.c
@@ -291,6 +291,7 @@ PGDLLEXPORT Datum gserialized_spgist_config_2d(PG_FUNCTION_ARGS)
spgConfigOut *cfg = (spgConfigOut *)PG_GETARG_POINTER(1);
Oid boxoid = InvalidOid;
boxoid = postgis_oid(BOX2DFOID);
diff --git a/postgis/gserialized_spgist_3d.c b/postgis/gserialized_spgist_3d.c
index b417baa..61953fa 100644
--- a/postgis/gserialized_spgist_3d.c
+++ b/postgis/gserialized_spgist_3d.c
@@ -374,6 +374,7 @@ PGDLLEXPORT Datum gserialized_spgist_config_3d(PG_FUNCTION_ARGS)
boxoid = postgis_oid(BOX3DOID);
diff --git a/postgis/gserialized_supportfn.c b/postgis/gserialized_supportfn.c
index d783337..ce53816 100644
--- a/postgis/gserialized_supportfn.c
+++ b/postgis/gserialized_supportfn.c
@@ -279,6 +279,12 @@ Datum postgis_index_supportfn(PG_FUNCTION_ARGS)
Node *rawreq = (Node *) PG_GETARG_POINTER(0);
Node *ret = NULL;
+ /* The support function need the cache to be populated to know what the type Oids are.
+ * Otherwise it will need look them up dynamically, which only works in the schema where Postgis
+ * is installed is part of the search path (Trac #4739)
if (IsA(rawreq, SupportRequestSelectivity))
SupportRequestSelectivity *req = (SupportRequestSelectivity *) rawreq;
diff --git a/postgis/lwgeom_out_geobuf.c b/postgis/lwgeom_out_geobuf.c
index 5db6c8e..f375397 100644
--- a/postgis/lwgeom_out_geobuf.c
+++ b/postgis/lwgeom_out_geobuf.c
@@ -52,6 +52,9 @@ Datum pgis_asgeobuf_transfn(PG_FUNCTION_ARGS)
MemoryContext aggcontext;
struct geobuf_agg_context *ctx;
if (!AggCheckCallContext(fcinfo, &aggcontext))
elog(ERROR, "pgis_asgeobuf_transfn: called in non-aggregate context");
MemoryContextSwitchTo(aggcontext);
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index 4d82148..5db0d0b 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -89,6 +89,7 @@ ST_AsGeoJsonRow(PG_FUNCTION_ARGS)
Oid geom_oid = InvalidOid;
Oid geog_oid = InvalidOid;
geom_oid = postgis_oid(GEOMETRYOID);
geog_oid = postgis_oid(GEOGRAPHYOID);
diff --git a/postgis/lwgeom_out_mvt.c b/postgis/lwgeom_out_mvt.c
index f1c72af..f46ec42 100644
--- a/postgis/lwgeom_out_mvt.c
+++ b/postgis/lwgeom_out_mvt.c
@@ -132,6 +132,9 @@ Datum pgis_asmvt_transfn(PG_FUNCTION_ARGS)
mvt_agg_context *ctx;
elog(ERROR, "%s called in non-aggregate context", __func__);
Summary of changes:
NEWS | 4 +++-
postgis/gserialized_estimate.c | 9 ++++++++-
postgis/gserialized_spgist_2d.c | 1 +
postgis/gserialized_spgist_3d.c | 1 +
postgis/gserialized_supportfn.c | 6 ++++++
postgis/lwgeom_out_geobuf.c | 3 +++
postgis/lwgeom_out_geojson.c | 1 +
postgis/lwgeom_out_mvt.c | 3 +++
8 files changed, 26 insertions(+), 2 deletions(-)
hooks/post-receive
