[postgis-tickets] [PostGIS] #4762: debbie makedist is failing
PostGIS trac at osgeo.org
Mon Oct 5 09:24:25 PDT 2020
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.1.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I'm guessing this might have something to do with MVT changes, but
 debbie's Make Dist for 3.1 is failing.
 5:58:37 generator.c:116:2: error: too many arguments to function
 ‘lwprint_double’
 05:58:37   116 |  lwprint_double(p.y + styles->pointSize, 10, y2,
 OUT_DOUBLE_BUFFER_SIZE);
 05:58:37       |  ^~~~~~~~~~~~~~
 05:58:37 In file included from generator.c:37:
 05:58:37 ../../../liblwgeom/liblwgeom_internal.h:454:5: note: declared
 here
 05:58:37   454 | int lwprint_double(double d, int maxdd, char *buf);
 05:58:37 generator.c: In function ‘main’:
 05:58:37 generator.c:356:2: warning: ‘strncat’ specified bound 3 equals
 source length [-Wstringop-overflow=]
 05:58:37   356 |  strncat( filename, "png", 3 );
 05:58:37       |  ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~
 05:58:37 make[2]: *** [Makefile:180: generator.o] Error 1
 though it's a bit puzzling to me how mvt would affect generate.c.
 https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/2121/consoleFull
 Regular build is okay but regular build doesn't try to do imagemagick
 generation of images.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4762>
