[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-81-g33db86a
git at osgeo.org
git at osgeo.org
Tue Oct 6 02:24:04 PDT 2020
the project "PostGIS".
via 33db86ac377e060f59c353ab7b44703ebfbf90aa (commit)
from 43b1f58ed8869d4a6d0b2c58cbecc49d407e39e2 (commit)
revisions in full, below.
commit 33db86ac377e060f59c353ab7b44703ebfbf90aa
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 6 11:02:49 2020 +0200
Fix schema variable name
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 8489bab..2389b42 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2938,7 +2938,7 @@ BEGIN
sql := format(
'CREATE EXTENSION %1$I SCHEMA %2$I VERSION unpackaged;'
'ALTER EXTENSION %1%I UPDATE TO %3$I',
- rec.name, install_schema, rec.default_version);
+ rec.name, var_schema, rec.default_version);
ELSE
sql := format(
'CREATE EXTENSION %1$I VERSION unpackaged;'
Summary of changes:
postgis/postgis.sql.in | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
