[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-82-g963aad2
git at osgeo.org
git at osgeo.org
Tue Oct 6 03:20:57 PDT 2020
the project "PostGIS".
via 963aad2943924702e03b180a82bd1412c0d5880e (commit)
from 33db86ac377e060f59c353ab7b44703ebfbf90aa (commit)
revisions in full, below.
commit 963aad2943924702e03b180a82bd1412c0d5880e
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 6 12:20:49 2020 +0200
Fix format string
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 2389b42..226fdff 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -2937,12 +2937,12 @@ BEGIN
THEN
sql := format(
'CREATE EXTENSION %1$I SCHEMA %2$I VERSION unpackaged;'
- 'ALTER EXTENSION %1%I UPDATE TO %3$I',
+ 'ALTER EXTENSION %1$I UPDATE TO %3$I',
rec.name, var_schema, rec.default_version);
ELSE
sql := format(
'CREATE EXTENSION %1$I VERSION unpackaged;'
- 'ALTER EXTENSION %1%I UPDATE TO %2$I',
+ 'ALTER EXTENSION %1$I UPDATE TO %2$I',
rec.name, rec.default_version);
END IF;
RAISE NOTICE 'Packaging extension %', rec.name;
Summary of changes:
postgis/postgis.sql.in | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
