[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Tue Oct 13 02:56:20 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
The affirmation "we add the most accurate lines first" is to be
considered. How can a line be accurate, if not ONLY via their
vertexes ? Vertexes are what you measure, not lines. Is this not
the case ?
Aren't vertexes inherently always the most accurate data at our
disposal ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:16>
