[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Wed Oct 14 13:29:02 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
On further analisys I think I found the culprit.
The code first nodes to existing edges and AFTER THAT snaps to existing
elements.
When snapping, the computed intersection nodes are not considered, and
thus can result in moving (snapping) those intersection nodes to near-by
elements (as the case above).
This should be fixed by simply doing all snapping up-front (before
noding).
I'll try this approach.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:19>
