[postgis-tickets] [PostGIS] #4758: ERROR: XX000: SQL/MM Spatial exception - geometry crosses edge 2, LOCATION: pg_error, lwgeom_pg.c:250
trac at osgeo.org
Tue Oct 13 04:03:43 PDT 2020
Reporter: laopsahl | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: | Keywords:
Comment (by laopsahl):
One problem when I describe things here is that I have not been accurate
enough when I talk about lines and vertexes, I will try to be more
accurate on this.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4758#comment:18>
