[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-90-gf8b9956
Wed Oct 14 22:36:02 PDT 2020
the project "PostGIS".
       via  f8b99564cd50874bad0371b40a821d91b04c3c39 (commit)
      from  13f821e5906e1a2663eb43b410bb6bd1deba88b6 (commit)
revisions in full, below.
commit f8b99564cd50874bad0371b40a821d91b04c3c39
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Oct 15 01:35:55 2020 -0400
    Add logic to install postgis_sfcgal lib, upgrade default versions of libraries
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 4e86959..d40cc35 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -17,13 +17,13 @@
 #!/usr/bin/env bash
 if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.8.1
-	export GDAL_VER=2.4.4
-	export PROJ_VER=5.2.0
-	export SFCGAL_VER=1.3.2
-	export CGAL_VER=4.11
+	export GDAL_VER=3.0.4
+	export PROJ_VER=6.3.2
+	export SFCGAL_VER=1.3.8
+	export CGAL_VER=5.0
 	export ICON_VER=1.15
 	export ZLIB_VER=1.2.11
-  	export PROTOBUF_VER=3.2.0
+  export PROTOBUF_VER=3.2.0
 	export PROTOBUFC_VER=1.2.1
 	export JSON_VER=0.12
 	export PROJSO=libproj-13.dll
@@ -53,7 +53,7 @@ fi;
 #set to something even if override is on but not set
 if  [[ "${CGAL_VER}" == '' ]] ; then
 fi;
 echo "ZLIB_VER $ZLIB_VER"
@@ -195,10 +195,12 @@ cp ${PROJECTS}/libxml/rel-libxml2-${LIBXML_VER}w${OS_BUILD}${GCC_TYPE}/bin/*.dll
 cd ${POSTGIS_SRC}
 strip postgis/*.dll
+strip sfcgal/*.dll
 strip raster/rt_pg/*.dll
 strip liblwgeom/.libs/*.dll
 cp postgis/*.dll ${RELDIR}/${RELVERDIR}/lib
+cp sfcgal/*.dll ${RELDIR}/${RELVERDIR}/lib
 cp topology/*.dll ${RELDIR}/${RELVERDIR}/lib
 cp raster/rt_pg/*.dll ${RELDIR}/${RELVERDIR}/lib
 cp doc/*_comments.sql ${RELDIR}/${RELVERDIR}/share/contrib/postgis-${POSTGIS_MINOR_VER}
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index 9eee87d..a89bb5e 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,9 +1,9 @@
 #!/usr/bin/env bash
 set -e
-	export GEOS_VER=3.8.0
+	export GEOS_VER=3.8.1
 	export CGAL_VER=5.0.2
@@ -134,8 +134,8 @@ fi
 if [ -n "$SFCGAL_VER" ]; then
 	##hard code versions of cgal etc. for now
-	BOOST_VER=1.53.0
+	#export CGAL_VER=4.11
+	BOOST_VER=1.59.0
 	#BOOST_VER_WU=1_49_0
 	export BOOST_VER_WU=1_53_0
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
@@ -191,6 +191,7 @@ if [ "$MAKE_EXTENSION" == "1" ]; then
  strip raster/rt_pg/postgis_raster-*.dll
  cp topology/*.dll ${PGPATHEDB}/lib
  cp postgis/postgis*.dll ${PGPATHEDB}/lib
+ cp sfcgal/*.dll ${PGPATHEDB}/lib
  cp raster/rt_pg/postgis_raster-*.dll ${PGPATHEDB}/lib
  cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}.sql ${PGPATHEDB}/share/extension
  cp -r ${PGPATH}/share/extension/postgis*${POSTGIS_MICRO_VER}next.sql ${PGPATHEDB}/share/extension
Summary of changes:
 ci/winnie/package_postgis.sh | 14 ++++++++------
 ci/winnie/regress_postgis.sh | 11 ++++++-----
 2 files changed, 14 insertions(+), 11 deletions(-)
hooks/post-receive
