[postgis-tickets] [PostGIS] #4721: SQL Error [XX000] with ST_AddEdgeModFace
trac at osgeo.org
Thu Oct 15 03:33:41 PDT 2020
Reporter: jeromeu | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.1.0
Component: topology | Version: 3.0.x
Resolution: | Keywords: topology edge Error
Comment (by strk):
In presence of an invalid topology (ValidteTopology returns a number of
errors, you say) any bet is off. What you could do to debug this is making
a copy of the topology (CopyTopology) and then reduce the size of it
incrementally while still being able to reproduce the issue. Then you
could enable debugging (in liblwgeom/lwgeom_topo.c and
topology/postgis_topology.c there are commented-out #define on top of the
file).
I'm interested in knowing if you have more info about this case.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4721#comment:5>
