[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-92-g7c05b5c
Thu Oct 15 07:26:38 PDT 2020
the project "PostGIS".
       via  7c05b5cdd8a9cf2b9f80666a0be2cac7cf06cd16 (commit)
       via  b1a18d427ed8a9a47dc94726aec4535d0e811c6d (commit)
      from  f8b99564cd50874bad0371b40a821d91b04c3c39 (commit)
revisions in full, below.
commit 7c05b5cdd8a9cf2b9f80666a0be2cac7cf06cd16
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Oct 15 02:12:25 2020 +0200
    Do not include non-isolated nodes twice to topology snap target
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 46823c8..964b7ae 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -5619,8 +5619,10 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
   int nearbyedgecount = nearbyindex;
-  /* 2.1. Find nodes falling within tol distance *
-   * TODO: check if we should be only considering _isolated_ nodes! */
+  /* 2.1. Find isolated nodes falling within tol distance
+   * TODO: add backend-interface support for only getting isolated nodes
   nodes = lwt_be_getNodeWithinBox2D( topo, &qbox, &numnodes, LWT_COL_NODE_ALL, 0 );
   if (numnodes == UINT64_MAX)
@@ -5642,6 +5644,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     for (i=0; i<numnodes; ++i)
       LWT_ISO_NODE *n = &(nodes[i]);
+      if ( n->containing_face == -1 ) continue; /* skip not-isolated nodes */
       LWGEOM *g = lwpoint_as_lwgeom(n->geom);
       double dist = lwgeom_mindistance2d(g, noded);
       /* must be closer than tolerated, unless distance is zero */
@@ -5653,7 +5656,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
       nearby[nearbyindex++] = g;
       ++nn;
-    LWDEBUGF(1, "Found %d nodes closer than tolerance (%g)", nn, tol);
+    LWDEBUGF(1, "Found %d isolated nodes closer than tolerance (%g)", nn, tol);
   int nearbynodecount = nearbyindex - nearbyedgecount;
   nearbycount = nearbyindex;
commit b1a18d427ed8a9a47dc94726aec4535d0e811c6d
Date:   Thu Oct 15 01:42:03 2020 +0200
    Improve topology noding robustness
    Avoids snapping again after noding.
    Fixes #4758
    Includes automated test
diff --git a/NEWS b/NEWS
index c5eec4e..49d9d96 100644
--- a/NEWS
+++ b/NEWS
@@ -13,6 +13,8 @@ Only tickets not included in 3.1.0alpha2
   - GEOS 3.9
 * Enhancements *
+  - #4758, Improve topology noding robustness (Sandro Santilli)
   - Make ST_Subdivide interruptable (Sandro Santilli)
   - #4660, Changes in double / coordinate printing (Raúl Marín)
         - Use the shortest representation (enough to guarantee roundtrip).
index 236a292..46823c8 100644
@@ -18,7 +18,7 @@
- * Copyright (C) 2015-2017 Sandro Santilli <strk at kbt.io>
+ * Copyright (C) 2015-2020 Sandro Santilli <strk at kbt.io>
@@ -5586,10 +5586,10 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
               tol, qbox.xmin, qbox.ymin, qbox.xmax, qbox.ymax);
   LWGEOM **nearby = 0;
-  int nearbyindex=0;
+  int nearbyindex = 0;
   int nearbycount = 0;
-  /* 2. Node to edges falling within tol distance */
+  /* 2.0. Find edges falling within tol distance */
   edges = lwt_be_getEdgeWithinBox2D( topo, &qbox, &numedges, LWT_COL_EDGE_ALL, 0 );
   if (numedges == UINT64_MAX)
@@ -5603,7 +5603,7 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     /* collect those whose distance from us is < tol */
     nearbycount += numedges;
-    nearby = lwalloc(nearbycount * sizeof(LWGEOM *));
+    nearby = lwalloc(numedges * sizeof(LWGEOM *));
     for (i=0; i<numedges; ++i)
       LW_ON_INTERRUPT(return NULL);
@@ -5615,56 +5615,11 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
       if ( dist && dist >= tol ) continue;
-    LWDEBUGF(2, "Found %d lines closer than tolerance (%g)", nearbyindex, tol);
-    if ( nearbyindex )
-      LWCOLLECTION *col;
-      LWGEOM *iedges; /* just an alias for col */
-      LWGEOM *snapped;
-      LWGEOM *set1, *set2;
-      LWDEBUGF(1, "Line intersects %d edges", nearbyindex);
-      col = lwcollection_construct(COLLECTIONTYPE, topo->srid,
-                                   NULL, nearbyindex, nearby);
-      iedges = lwcollection_as_lwgeom(col);
-      LWDEBUGG(1, iedges, "Collected edges");
-      LWDEBUGF(1, "Snapping noded, with srid=%d "
-                  "to interesecting edges, with srid=%d",
-                  noded->srid, iedges->srid);
-      snapped = _lwt_toposnap(noded, iedges, tol);
-      lwgeom_free(noded);
-      LWDEBUGG(1, snapped, "Snapped");
-      LWDEBUGF(1, "Diffing snapped, with srid=%d "
-                  "and interesecting edges, with srid=%d",
-                  snapped->srid, iedges->srid);
-      noded = lwgeom_difference(snapped, iedges);
-      LWDEBUGG(1, noded, "Differenced");
-      LWDEBUGF(1, "Intersecting snapped, with srid=%d "
-      set1 = lwgeom_intersection(snapped, iedges);
-      LWDEBUGG(1, set1, "Intersected");
-      lwgeom_free(snapped);
-      LWDEBUGF(1, "Linemerging set1, with srid=%d", set1->srid);
-      set2 = lwgeom_linemerge(set1);
-      LWDEBUGG(1, set2, "Linemerged");
-      LWDEBUGG(1, noded, "Noded");
-      lwgeom_free(set1);
-      LWDEBUGF(1, "Unioning noded, with srid=%d "
-                  "and set2, with srid=%d", noded->srid, set2->srid);
-      set1 = lwgeom_union(noded, set2);
-      lwgeom_free(set2);
-      noded = set1;
-      LWDEBUGG(1, set1, "Unioned");
-      /* will not release the geoms array */
-      lwcollection_release(col);
+    LWDEBUGF(1, "Found %d edges closer than tolerance (%g)", nearbyindex, tol);
+  int nearbyedgecount = nearbyindex;
-  /* 2.1. Node with existing nodes within tol
+  /* 2.1. Find nodes falling within tol distance *
@@ -5674,11 +5629,10 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     return NULL;
   LWDEBUGF(1, "Line bbox intersects %d nodes bboxes", numnodes);
-  int nearbyedgecount = nearbyindex;
   if ( numnodes )
-    nearbycount = nearbyindex + numnodes;
+    nearbycount = nearbyedgecount + numnodes;
     nearby = nearby ?
         lwrealloc(nearby, nearbycount * sizeof(LWGEOM *))
@@ -5691,21 +5645,29 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
-      if ( dist && dist >= tol ) continue;
+      if ( dist && dist >= tol )
+        LWDEBUGF(1, "Node %d is %g units away, we tolerate only %g", n->node_id, dist, tol);
+        continue;
       ++nn;
+    LWDEBUGF(1, "Found %d nodes closer than tolerance (%g)", nn, tol);
+  int nearbynodecount = nearbyindex - nearbyedgecount;
+  nearbycount = nearbyindex;
-  LWDEBUGF(1, "Number of nearby elements is %d", nearbyindex);
+  LWDEBUGF(1, "Number of nearby elements is %d", nearbycount);
-  if ( numnodes )
+  /* 2.2. Snap to nearby elements */
+  if ( nearbycount )
     LWCOLLECTION *col;
     LWGEOM *elems;
+                                 NULL, nearbycount, nearby);
     elems = lwcollection_as_lwgeom(col);
     LWDEBUGG(1, elems, "Collected nearby elements");
@@ -5718,20 +5680,6 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
-    if ( numnodes )
-      col = lwcollection_construct(MULTIPOINTTYPE, topo->srid,
-                             NULL, nearbyindex-nearbyedgecount,
-                             nearby + nearbyedgecount);
-      LWGEOM *inodes = lwcollection_as_lwgeom(col);
-      tmp = _lwt_split_by_nodes(noded, inodes);
-      noded = tmp;
-      LWDEBUGG(1, noded, "Node-split");
     -- re-node to account for ST_Snap introduced self-intersections
     -- See http://trac.osgeo.org/postgis/ticket/1714
@@ -5741,11 +5689,110 @@ _lwt_AddLine(LWT_TOPOLOGY* topo, LWLINE* line, double tol, int* nedges,
     lwgeom_free(noded);
     noded = tmp;
     LWDEBUGG(1, noded, "Unary-unioned");
+  /* 2.3. Node with nearby edges */
+  if ( nearbyedgecount )
+    LWCOLLECTION *col;
+    LWGEOM *iedges; /* just an alias for col */
+    LWGEOM *diff, *xset;
+    LWDEBUGF(1, "Line intersects %d edges", nearbyedgecount);
+    col = lwcollection_construct(COLLECTIONTYPE, topo->srid,
+                                 NULL, nearbyedgecount, nearby);
+    iedges = lwcollection_as_lwgeom(col);
+    LWDEBUGG(1, iedges, "Collected edges");
+    LWDEBUGF(1, "Diffing noded, with srid=%d "
+                "and interesecting edges, with srid=%d",
+                noded->srid, iedges->srid);
+    diff = lwgeom_difference(noded, iedges);
+    LWDEBUGG(1, diff, "Differenced");
+    LWDEBUGF(1, "Intersecting noded, with srid=%d "
+    xset = lwgeom_intersection(noded, iedges);
+    LWDEBUGG(1, xset, "Intersected");
+    lwgeom_free(noded);
+    /* We linemerge here because INTERSECTION, as of GEOS 3.8,
+     * will result in shared segments being output as multiple
+     * lines rather than a single line. Example:
+          INTERSECTION(
+            'LINESTRING(0 0, 5 0, 8 0, 10 0,12 0)',
+            'LINESTRING(5 0, 8 0, 10 0)'
+          MULTILINESTRING((5 0,8 0),(8 0,10 0))
+     * We will re-split in a subsequent step, by splitting
+     * the final line with pre-existing nodes
+    LWDEBUG(1, "Linemerging intersection");
+    tmp = lwgeom_linemerge(xset);
+    LWDEBUGG(1, tmp, "Linemerged");
+    lwgeom_free(xset);
+    xset = tmp;
+     * Here we union the (linemerged) intersection with
+     * the difference (new lines)
+    LWDEBUG(1, "Unioning difference and (linemerged) intersection");
+    noded = lwgeom_union(diff, xset);
+    LWDEBUGG(1, noded, "Diff-Xset Unioned");
+    lwgeom_free(diff);
+    /* will not release the geoms array */
+    lwcollection_release(col);
+  /* 2.4. Split by pre-existing nodes
+   * Pre-existing nodes are isolated nodes AND endpoints
+   * of intersecting edges
+    nearbycount += nearbyedgecount * 2; /* make space for endpoints */
+    nearby = lwrealloc(nearby, nearbycount * sizeof(LWGEOM *));
+    for (int i=0; i<nearbyedgecount; i++)
+      LWLINE *edge = lwgeom_as_lwline(nearby[i]);
+      LWPOINT *startNode = lwline_get_lwpoint(edge, 0);
+      LWPOINT *endNode = lwline_get_lwpoint(edge, edge->points->npoints-1);
+      /* TODO: only add if within distance to noded AND if not duplicated */
+      nearby[nearbyindex++] = lwpoint_as_lwgeom(startNode);
+      nearbynodecount++;
+      nearby[nearbyindex++] = lwpoint_as_lwgeom(endNode);
+  if ( nearbynodecount )
+    col = lwcollection_construct(MULTIPOINTTYPE, topo->srid,
+                             NULL, nearbynodecount,
+                             nearby + nearbyedgecount);
+    LWGEOM *inodes = lwcollection_as_lwgeom(col);
+    /* TODO: use lwgeom_split of lwgeom_union ... */
+    tmp = _lwt_split_by_nodes(noded, inodes);
+    noded = tmp;
+    LWDEBUGG(1, noded, "Node-split");
   LWDEBUG(1, "Freeing up nearby elements");
+  /* TODO: free up endpoints of nearbyedges */
   if ( nearby ) lwfree(nearby);
   if ( nodes ) _lwt_release_nodes(nodes, numnodes);
   if ( edges ) _lwt_release_edges(edges, numedges);
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index fc194de..74de66e 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -387,3 +387,13 @@ SELECT 't4757.0', topology.TopoGeo_addPoint('bug4757', 'POINT(0 0)');
 SELECT 't4757.1', topology.TopoGeo_addLinestring('bug4757',
   'LINESTRING(0 -0.1,1 0,1 1,0 1,0 -0.1)', 1);
 SELECT 't4757.end', topology.DropTopology('bug4757');
+-- See https://trac.osgeo.org/postgis/ticket/t4758
+select 't4758.start', topology.CreateTopology ('t4758', 0, 1e-06) > 0;
+select 't4758.0', topology.TopoGeo_addLinestring('t4758',
+  'LINESTRING(11.38327215  60.4081942, 11.3826176   60.4089484)');
+select 't4758.1', topology.TopoGeo_addLinestring('t4758',
+  'LINESTRING( 11.3832721  60.408194249999994, 11.38327215 60.4081942)');
+select 't4758.2', topology.TopoGeo_addLinestring('t4758',
+  'LINESTRING( 11.38330505 60.408239599999995, 11.3832721  60.408194249999994)');
+SELECT 't4758.end', topology.DropTopology('t4758');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index c760d95..2001ed6 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -162,12 +162,13 @@ iso_ex_2segs|28
 #1706.2|N||POINT(10 10)
 #1706.2|E|LINESTRING(10 0,10 10)
 #1706.2|E|LINESTRING(15 10,10 10)
+#1706.2|E|LINESTRING(9 12,15 10)
 #1706.2|E|LINESTRING(10 10,9 12)
 #1706.2|E|LINESTRING(20 10,15 10)
 #1706.2|E|LINESTRING(9 12,10 20)
 #1714.1|N|77
 #1714.1|N|0|POINT(10 0)
-#1714.2|E*|74
+#1714.2|E*|75
 #1714.2|N||POINT(0 20)
 #1714.2|E|LINESTRING(10 0,0 20)
 Topology 'city_data' dropped
@@ -197,7 +198,7 @@ t3371.L2|2
 t3371.end|Topology 'bug3711' dropped
 t3838.start|t
 t3838.L1|1
-t3838.L2|9
+t3838.L2|6
 t3838.end|Topology 'bug3838' dropped
 t1855_1.start|t
 t1855_1.0|1
@@ -209,3 +210,10 @@ t1855_2.end|Topology 'bug1855' dropped
 t4757.start|t
 t4757.0|1
 t4757.end|Topology 'bug4757' dropped
+t4758.start|t
+t4758.0|1
+t4758.1|2
+t4758.2|4
+t4758.2|5
+t4758.2|2
+t4758.end|Topology 't4758' dropped
Summary of changes:
 NEWS                                               |   2 +
 liblwgeom/lwgeom_topo.c                            | 196 +++++++++++++--------
 topology/test/regress/topogeo_addlinestring.sql    |  10 ++
 .../test/regress/topogeo_addlinestring_expected    |  12 +-
 4 files changed, 145 insertions(+), 75 deletions(-)
hooks/post-receive
