[postgis-tickets] [PostGIS] #4773: debbie pg13 failing on unpackaged
trac at osgeo.org
Wed Oct 21 21:56:25 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: buildbots | Version: master
Keywords: pg13 |
Did we somehow reenable this for pg13 or is it a configuration issue.
Just noticed Debbie's PG13 trunk runs are failing
https://debbie.postgis.net/job/PostGIS_Regress/15304/consoleFull
22:56:39 ERROR: CREATE EXTENSION ... FROM is no longer supported
22:56:39 LINE 1: CREATE EXTENSION postgis VERSION '3.1.0dev' FROM
unpackaged;
22:56:39 ^
22:56:39
22:56:39 make: *** [Makefile:184: check] Error 1
22:56:39 make: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/3.1/raster/test/regress'
22:56:39 FAIL: upgrade unpackaged3.1--3.1.0dev
22:56:39 Build step 'Execute shell' marked build as failure
22:56:39 Triggering a new build of PostgreSQL stop
22:56:39 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4773>
