[postgis-tickets] [PostGIS] #4773: debbie pg13 failing on unpackaged
trac at osgeo.org
Thu Oct 22 02:20:19 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: buildbots | Version: master
Resolution: | Keywords: pg13
Comment (by strk):
The run_test.pl script should now only use CREATE..FROM
when the target PostgreSQL version is < 13
Since 520af0e8d1bb6e9544d974713bb87e428ff4230b/git
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4773#comment:1>
