[postgis-tickets] [PostGIS] #4773: debbie pg13 failing on unpackaged
trac at osgeo.org
Mon Oct 26 12:05:38 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: buildbots | Version: master
Resolution: | Keywords: pg13
Comment (by robe):
LOoks like it broke after this commit
Commit 520af0e8d1bb6e9544d974713bb87e428ff4230b by strk
Work around PG13 drop of `FROM unpackaged` syntax
- Always install empty extension--unpackage.sql scripts
- Have run_test.pl use create/update trick for PG13
- Re-enable check_all_upgrades.sh testing of unpackaged
- Have postgis_extensions_upgrade use the unpackaged trick
Fixes #4643
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4773#comment:2>
