[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-95-g23c15ff
Fri Oct 23 05:46:56 PDT 2020
the project "PostGIS".
       via  23c15ffa5e7e9a9e7783e859c5912cde51bcc592 (commit)
      from  a7851bb0659a86ed63f183fd8f536aa83942add7 (commit)
revisions in full, below.
commit 23c15ffa5e7e9a9e7783e859c5912cde51bcc592
Author: Raúl Marín <git at rmr.ninja>
Date:   Sun Oct 18 00:39:51 2020 +0200
    Fix segfault in st_addband
    References #4769
    Closes https://github.com/postgis/postgis/pull/585/
diff --git a/NEWS b/NEWS
index 9de0012..ec3545c 100644
--- a/NEWS
+++ b/NEWS
@@ -47,7 +47,7 @@ Only tickets not included in 3.1.0alpha2
            as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina Obe)
   - #4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)
   - #4767, #4768, #4771, #4772, Fix segfault when parsing invalid WKB (Raúl Marín)
+  - #4769, Fix segfault in st_addband (Raúl Marín)
 PostGIS 3.1.0alpha2
diff --git a/raster/rt_pg/rtpg_create.c b/raster/rt_pg/rtpg_create.c
index 992fc51..f69865a 100644
--- a/raster/rt_pg/rtpg_create.c
+++ b/raster/rt_pg/rtpg_create.c
@@ -383,6 +383,17 @@ Datum RASTER_addBandRasterArray(PG_FUNCTION_ARGS)
 		POSTGIS_RT_DEBUG(4, "destination raster isn't NULL");
+	if (PG_ARGISNULL(1))
+		if (raster != NULL)
+			rt_raster_destroy(raster);
+			PG_RETURN_POINTER(pgraster);
+		else
+			PG_RETURN_NULL();
 	/* source rasters' band index, 1-based */
 	if (!PG_ARGISNULL(2))
 		srcnband = PG_GETARG_INT32(2);
diff --git a/raster/test/regress/tickets.sql b/raster/test/regress/tickets.sql
index 5520634..711a7ad 100644
--- a/raster/test/regress/tickets.sql
+++ b/raster/test/regress/tickets.sql
@@ -142,3 +142,6 @@ INSERT INTO ticket_4547 VALUES (null);
 INSERT INTO ticket_4547 SELECT ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);
 SELECT '#4547.2', AddRasterConstraints('ticket_4547', 'r');
 DROP TABLE ticket_4547;
+-- #4769
+SELECT '#4769', st_addband(NULL, NULL::_raster, 1, 1);
\ No newline at end of file
diff --git a/raster/test/regress/tickets_expected b/raster/test/regress/tickets_expected
index d3b27ae..ae1f56b 100644
--- a/raster/test/regress/tickets_expected
+++ b/raster/test/regress/tickets_expected
@@ -69,3 +69,4 @@ NOTICE:  Adding nodata value constraint
 NOTICE:  Adding out-of-database constraint
 NOTICE:  Adding maximum extent constraint
 #4547.2|t
+#4769|
Summary of changes:
 NEWS                                 |  2 +-
 raster/rt_pg/rtpg_create.c           | 11 +++++++++++
 raster/test/regress/tickets.sql      |  3 +++
 raster/test/regress/tickets_expected |  1 +
 4 files changed, 16 insertions(+), 1 deletion(-)
hooks/post-receive
