[postgis-tickets] [PostGIS] #4774: How to set the geometry parameter of ST_TileEnvelope when 2 tiles exist at zoom level zero
trac at osgeo.org
Fri Oct 23 05:48:09 PDT 2020
zoom level zero
Reporter: jingsam | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.3
Component: postgis | Version: 2.5.x
Resolution: wontfix | Keywords:
Comment (by komzpa):
I had to do that in the past for Landsat imagery. I did it via defining an
larger extent and only using zooms from 1, which contained 4 tiles of
which only upper 2 were explored.
That required a base box of (-180.0, -166.0, 332.0, 346.0), but
afterwards the grids were aligned:
https://github.com/Komzpa/twms/blob/master/twms/projections.py#L31
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4774#comment:2>
