[postgis-tickets] [PostGIS] #4775: [3.1] Performance regression on gserialized_overlaps_2d
PostGIS trac at osgeo.org
Fri Oct 23 06:40:51 PDT 2020
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  medium      |  Milestone:  PostGIS 3.1.0
Component:  postgis     |    Version:  master
 Keywords:              |
 While doing a perf check over 3.1 I've noticed a slowdown on some MVT
 queries (the only ones I'm running).
 The underlying database is exactly the same, with the same query and plan
 (I just changed the .so library), and when I compare the perf output of
 both 3.0 and 3.1 I get this:
 - 3.0 (only the gserialized_overlaps_2d part)
 -   11.76%     1.24%  postgres  postgis-3.so            [.]
 gserialized_overlaps_2d                                         ▒
    - 10.52% gserialized_overlaps_2d
       - 9.96% gserialized_datum_get_box2df_p
          - 3.19% gserialized2_get_gbox_p
             - 2.78% gserialized2_peek_gbox_p
                  1.25% gbox_float_round
                  0.85% nextafterf32
            1.78% __memmove_avx_unaligned_erms
          - 1.34% heap_tuple_untoast_attr
             - 0.77% palloc
                  AllocSetAlloc
            0.61% AllocSetFree
    - 0.80% __libc_start_main
         0x5569d1f94705
         PostmasterMain
         __restore_rt
         sigusr1_handler
         0x5569d202d837
         StartBackgroundWorker
         ParallelWorkerMain
         ParallelQueryMain
         standard_ExecutorRun
         ExecAgg
         fetch_input_tuple
       - ExecScan
          - 0.80% ExecInterpExpr
               0.70% gserialized_overlaps_2
 * 3.1 (gserialized_overlaps_2d part):
    - 20.41% gserialized_overlaps_2d
       - 20.01% gserialized_datum_predicate_2d
          - 15.83% gserialized_datum_get_internals_p
             - 4.42% gserialized2_get_gbox_p
                - 2.50% gserialized2_peek_gbox_p
                     1.22% gbox_float_round
                     0.79% nextafterf32
                  1.32% gserialized2_read_gbox_p.llvm.13873022969809935523
             - 4.31% heap_tuple_untoast_attr_slice
                - 1.85% palloc
                     AllocSetAlloc
               1.43% __memmove_avx_unaligned_erms
               1.09% AllocSetFree
               0.68% heap_tuple_untoast_attr
 So it has gone from ~12% of the query to ~20% of the CPU time spent in the
 query.
 I did tinker around these functions for #4676 so that's likely to be the
 culprit.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4775>
