[postgis-tickets] [PostGIS] #4775: [3.1] Performance regression on gserialized_overlaps_2d
trac at osgeo.org
Fri Oct 23 07:59:46 PDT 2020
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
I've discovered 2 issues:
- I changed gserialized_datum_predicate_2d to use use GBOX, so it does a
double conversion: it gets the float box, creates a gbox using doubles and
then downcasts it to float again.
- PG_DETOAST_DATUM_SLICE always returns a copy of the datum even if it
doesn't need to do anything with it (external, indirect, expanded,
compressed), so for small geometries (untoasted) we are doing an extra
copy and free that we didn't do before. I'm thinking on a more addecuate
function for this case where we don't do anything to the datum if we don't
need to, and only get a slice if we do because of how it was stored.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4775#comment:1>
