[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-97-ge7c3c7f
Mon Oct 26 14:08:52 PDT 2020
the project "PostGIS".
       via  e7c3c7f2a5d46d27fa7a7a4b0886d263265e6b72 (commit)
      from  283a8c4733bbcfd6fd0e9cae0eb02850dd0acc94 (commit)
revisions in full, below.
commit e7c3c7f2a5d46d27fa7a7a4b0886d263265e6b72
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Oct 26 22:07:38 2020 +0100
    Drop duplicated and mis-scoped variable, fixing PG13 unpackaged test
    Fixes #4643 for real
    Closes #4773
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 7e4751e..8497ae4 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -431,7 +431,6 @@ my $geosver =  sql("select postgis_geos_version()");
 my $projver = sql("select postgis_proj_version()");
 my $libbuilddate = sql("select postgis_lib_build_date()");
 my $pgsqlver = sql("select version()");
-my $pgsqlvernum = sql("select current_setting('server_version_num')");
 my $gdalver = sql("select postgis_gdal_version()") if $OPT_WITH_RASTER;
 my $sfcgalver = sql("select postgis_sfcgal_version()") if $OPT_WITH_SFCGAL;
 my $scriptver = sql("select postgis_scripts_installed()");
@@ -1531,7 +1530,7 @@ sub package_extension_sql
 	my ($extname, $extver) = @_;
 	my $sql;
-	if ( $pgsqlvernum lt 130000 ) {
+	if ( $pgvernum lt 130000 ) {
 		$sql = "CREATE EXTENSION ${extname} VERSION '${extver}' FROM unpackaged;";
 	} else {
 		$sql = "CREATE EXTENSION ${extname} VERSION unpackaged;";
Summary of changes:
 regress/run_test.pl | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
hooks/post-receive
