[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-98-g06fa4cf
git at osgeo.org
git at osgeo.org
Tue Oct 27 14:26:36 PDT 2020
the project "PostGIS".
via 06fa4cfd3991a33b5d1bda3bb7cc7888ffeb52b3 (commit)
from e7c3c7f2a5d46d27fa7a7a4b0886d263265e6b72 (commit)
revisions in full, below.
commit 06fa4cfd3991a33b5d1bda3bb7cc7888ffeb52b3
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 27 22:26:04 2020 +0100
Draft utility script to test pg_upgrade
diff --git a/utils/check_cluster_upgrade.sh b/utils/check_cluster_upgrade.sh
new file mode 100755
index 0000000..0450194
--- /dev/null
+++ b/utils/check_cluster_upgrade.sh
@@ -0,0 +1,109 @@
+#!/bin/sh
+TMPDIR=/tmp/pgis_upgrade_test-$$/
+DATADIR=${TMPDIR}/cluster
+LOGFILE=${TMPDIR}/log
+export PGPORT=15432
+export PGHOST=${TMPDIR}
+export PGDATABASE=pgis
+PG_CONFIG_OLD=
+PG_CONFIG_NEW=
+usage() {
+ echo "Usage: $0 <pg_config> <pg_config>"
+cleanup() {
+ ${BIN_OLD}/pg_ctl -D ${DATADIR} stop || exit 1
+ rm -rf ${TMPDIR}
+trap 'cleanup' EXIT
+mkdir -p ${TMPDIR}
+while test -n "$1"; do
+ if test -z "$PG_CONFIG_OLD"; then
+ PG_CONFIG_OLD="$1"
+ shift
+ elif test -z "$PG_CONFIG_NEW"; then
+ PG_CONFIG_NEW="$1"
+ shift
+ else
+ echo "Unrecognized argument: $1" >&2
+ usage >&2
+ exit 1
+ fi
+done
+if test -z "$PG_CONFIG_NEW"; then
+ echo "Missing new pg_config path" >&2
+ usage >&2
+ exit 1
+fi
+if test "$PG_CONFIG_OLD" = "$PG_CONFIG_NEW"; then
+ echo "Old and new pg_config paths need be different" >&2
+ exit 1
+fi
+BIN_OLD=$(${PG_CONFIG_OLD} --bindir)
+BIN_NEW=$(${PG_CONFIG_NEW} --bindir)
+echo "Testing cluster upgrade"
+echo "FROM: $(${PG_CONFIG_OLD} --version)"
+echo " TO: $(${PG_CONFIG_NEW} --version)"
+echo "Creating FROM cluster"
+${BIN_OLD}/initdb ${DATADIR} > ${LOGFILE} 2>&1 || {
+ cat ${LOGFILE} && exit 1
+echo "Starting FROM cluster"
+${BIN_OLD}/pg_ctl -D ${DATADIR} -o "-F -p ${PGPORT} -k ${TMPDIR}" -l ${LOGFILE} start || {
+echo "Creating FROM db"
+${BIN_OLD}/createdb pgis || exit 1
+${BIN_OLD}/psql -c "CREATE EXTENSION postgis" || exit 1
+echo "---- OLD cluster info -------------------------"
+${BIN_OLD}/psql -XAt <<EOF || exit 1
+SELECT version();
+SELECT postgis_full_version();
+EOF
+echo "-----------------------------------------------"
+echo "Stopping FROM cluster"
+${BIN_OLD}/pg_ctl -D ${DATADIR} stop || exit 1
+export PGDATAOLD=${DATADIR}.old
+mv ${DATADIR} ${PGDATAOLD}
+export PGDATANEW=${DATADIR}
+echo "Creating TO cluster"
+${BIN_NEW}/initdb ${PGDATANEW} > ${LOGFILE} 2>&1 || {
+echo "Upgrading cluster"
+cd ${TMPDIR}
+${BIN_NEW}/pg_upgrade --link -b ${BIN_OLD} -B ${BIN_NEW} > ${LOGFILE} 2>&1 || {
+echo "Starting TO cluster"
+${BIN_NEW}/pg_ctl -D ${DATADIR} -o "-F -p ${PGPORT} -k ${TMPDIR}" -l ${LOGFILE} start || {
+echo "---- NEW cluster info -------------------------"
+${BIN_NEW}/psql -XAx <<EOF || exit 1
+SELECT version();
+SELECT postgis_extensions_upgrade();
+EOF
Summary of changes:
utils/check_cluster_upgrade.sh | 109 +++++++++++++++++++++++++++++++++++++++++
1 file changed, 109 insertions(+)
create mode 100755 utils/check_cluster_upgrade.sh
hooks/post-receive
