[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-99-gc1b8d14
git at osgeo.org
git at osgeo.org
Tue Oct 27 14:52:51 PDT 2020
the project "PostGIS".
via c1b8d14d8900dc835fd5782f364364ffa963919e (commit)
from 06fa4cfd3991a33b5d1bda3bb7cc7888ffeb52b3 (commit)
revisions in full, below.
commit c1b8d14d8900dc835fd5782f364364ffa963919e
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Oct 27 22:52:27 2020 +0100
Have check_cluster_upgrade.sh support init script
diff --git a/utils/check_cluster_upgrade.sh b/utils/check_cluster_upgrade.sh
index 0450194..8b530a6 100755
--- a/utils/check_cluster_upgrade.sh
+++ b/utils/check_cluster_upgrade.sh
@@ -3,6 +3,7 @@
TMPDIR=/tmp/pgis_upgrade_test-$$/
DATADIR=${TMPDIR}/cluster
LOGFILE=${TMPDIR}/log
+INIT_SCRIPT=
export PGPORT=15432
export PGHOST=${TMPDIR}
export PGDATABASE=pgis
@@ -10,7 +11,7 @@ PG_CONFIG_OLD=
PG_CONFIG_NEW=
usage() {
- echo "Usage: $0 <pg_config> <pg_config>"
+ echo "Usage: $0 [-i <init_script>] <pg_config_old> <pg_config_new>"
cleanup() {
@@ -23,7 +24,11 @@ trap 'cleanup' EXIT
mkdir -p ${TMPDIR}
while test -n "$1"; do
- if test -z "$PG_CONFIG_OLD"; then
+ if test "$1" = "-i"; then
+ shift
+ INIT_SCRIPT=$1
+ shift
+ elif test -z "$PG_CONFIG_OLD"; then
PG_CONFIG_OLD="$1"
shift
elif test -z "$PG_CONFIG_NEW"; then
@@ -66,10 +71,16 @@ ${BIN_OLD}/pg_ctl -D ${DATADIR} -o "-F -p ${PGPORT} -k ${TMPDIR}" -l ${LOGFILE}
echo "Creating FROM db"
${BIN_OLD}/createdb pgis || exit 1
-${BIN_OLD}/psql -c "CREATE EXTENSION postgis" || exit 1
+#TODO: run an custom script
+if test -n "$INIT_SCRIPT"; then
+ ${BIN_OLD}/psql -X --set ON_ERROR_STOP=1 -f "$INIT_SCRIPT" || exit 1
+else
+ ${BIN_OLD}/psql -Xc --set ON_ERROR_STOP=1 "CREATE EXTENSION postgis" || exit 1
+fi
echo "---- OLD cluster info -------------------------"
-${BIN_OLD}/psql -XAt <<EOF || exit 1
+${BIN_OLD}/psql -XAt --set ON_ERROR_STOP=1 <<EOF || exit 1
SELECT version();
SELECT postgis_full_version();
EOF
Summary of changes:
utils/check_cluster_upgrade.sh | 19 +++++++++++++++----
1 file changed, 15 insertions(+), 4 deletions(-)
hooks/post-receive
