[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-101-g47e75c4
git at osgeo.org
git at osgeo.org
Wed Oct 28 14:15:29 PDT 2020
the project "PostGIS".
via 47e75c49349ad1b89a9b93605cfe98211744180f (commit)
from 50b1e70b1a9d14b2e152dce4416247149ac3f77c (commit)
revisions in full, below.
commit 47e75c49349ad1b89a9b93605cfe98211744180f
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Oct 28 22:12:55 2020 +0100
Load each regress test in its own directory
Closes #4777 by making it allowed to use hard-coded paths
Update topology tests so hard-coded paths are relative to the
script file rather than the supposed calling path, allowing
them to be run from any directory too
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 8497ae4..d19adf2 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -789,13 +789,15 @@ sub run_simple_test
chmod 0777, $betmpdir;
my $scriptdir = scriptdir($libver, $OPT_EXTENSIONS);
- my $cmd = "psql -v \"VERBOSITY=terse\""
+ my ($sqlfile,$sqldir) = fileparse($sql);
+ my $cmd = "cd $sqldir; psql -v \"VERBOSITY=terse\""
. " -v \"tmpfile='$tmpfile'\""
. " -v \"scriptdir=$scriptdir\""
. " -v \"regdir=$REGDIR\""
. " -v \"schema=$OPT_SCHEMA.\""
. " -c \"SET search_path TO public,$OPT_SCHEMA,topology\""
- . " -tXAq -f $sql $DB > $outfile 2>&1";
+ . " -tXAq -f $sqlfile $DB > $outfile 2>&1";
my $rv = system($cmd);
# Check for ERROR lines
diff --git a/topology/test/regress/cleartopogeom.sql b/topology/test/regress/cleartopogeom.sql
index e3697db..6f27f76 100644
--- a/topology/test/regress/cleartopogeom.sql
+++ b/topology/test/regress/cleartopogeom.sql
@@ -1,8 +1,8 @@
\set VERBOSITY terse
set client_min_messages to ERROR;
-\i load_topology.sql
-\i load_features.sql
+\i ../load_topology.sql
+\i ../load_features.sql
SELECT 'relation before', count(distinct topogeo_id)
FROM city_data.relation
diff --git a/topology/test/regress/copytopology.sql b/topology/test/regress/copytopology.sql
index 7440828..aca4a2a 100644
--- a/topology/test/regress/copytopology.sql
+++ b/topology/test/regress/copytopology.sql
@@ -1,8 +1,8 @@
set client_min_messages to WARNING;
-\i load_topology-4326.sql
-\i more_features.sql
+\i ../load_topology-4326.sql
+\i ../more_features.sql
SELECT topology.CopyTopology('city_data', 'CITY_data_UP_down') > 0;
diff --git a/topology/test/regress/getnodeedges.sql b/topology/test/regress/getnodeedges.sql
index f5f8e3e..e4198b1 100644
--- a/topology/test/regress/getnodeedges.sql
+++ b/topology/test/regress/getnodeedges.sql
@@ -1,6 +1,6 @@
SELECT 'N'||node_id, (topology.GetNodeEdges('city_data', node_id)).*
FROM city_data.node ORDER BY node_id, sequence;
diff --git a/topology/test/regress/getringedges.sql b/topology/test/regress/getringedges.sql
index 20874e5..88b4bd4 100644
--- a/topology/test/regress/getringedges.sql
+++ b/topology/test/regress/getringedges.sql
@@ -1,6 +1,6 @@
SELECT 'R'||edge_id, (topology.GetRingEdges('city_data', edge_id)).*
FROM city_data.edge;
diff --git a/topology/test/regress/gettopogeomelements.sql b/topology/test/regress/gettopogeomelements.sql
index 5d765ba..e3a70af 100644
--- a/topology/test/regress/gettopogeomelements.sql
+++ b/topology/test/regress/gettopogeomelements.sql
@@ -1,7 +1,7 @@
SELECT lid, tid, GetTopoGeomElements('city_data', lid, tid)
FROM (
diff --git a/topology/test/regress/gml.sql b/topology/test/regress/gml.sql
index 58fcb51..0582ca7 100644
--- a/topology/test/regress/gml.sql
+++ b/topology/test/regress/gml.sql
@@ -1,8 +1,8 @@
--- Puntual single element {
diff --git a/topology/test/regress/legacy_invalid.sql b/topology/test/regress/legacy_invalid.sql
index 25187f4..bb2f916 100644
--- a/topology/test/regress/legacy_invalid.sql
+++ b/topology/test/regress/legacy_invalid.sql
@@ -1,6 +1,6 @@
-\i invalid_topology.sql
+\i ../invalid_topology.sql
-- clean up
SELECT topology.DropTopology('invalid_topology');
diff --git a/topology/test/regress/legacy_predicate.sql b/topology/test/regress/legacy_predicate.sql
index 567d2f6..88ee4da 100644
--- a/topology/test/regress/legacy_predicate.sql
+++ b/topology/test/regress/legacy_predicate.sql
@@ -1,10 +1,10 @@
-\i hierarchy.sql
-\i topo_predicates.sql
+\i ../hierarchy.sql
+\i ../topo_predicates.sql
-- clean up
SELECT topology.DropTopology('city_data');
diff --git a/topology/test/regress/legacy_query.sql b/topology/test/regress/legacy_query.sql
index d0b903d..21d0fd3 100644
--- a/topology/test/regress/legacy_query.sql
+++ b/topology/test/regress/legacy_query.sql
@@ -2,11 +2,11 @@ set client_min_messages to WARNING;
-- Tests TopoGeometry->Geometry cast and id(TopoGeometry)
-\i hierarchy.sql
-\i query_features.sql
+\i ../query_features.sql
-- clean up
diff --git a/topology/test/regress/legacy_validate.sql b/topology/test/regress/legacy_validate.sql
index d325e70..1dd8f04 100644
--- a/topology/test/regress/legacy_validate.sql
+++ b/topology/test/regress/legacy_validate.sql
@@ -1,7 +1,7 @@
-\i validate_topology.sql
+\i ../validate_topology.sql
-- clean up
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 2939c22..047bd6c 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -1,6 +1,6 @@
-- Endpoint / node mismatch
SELECT topology.ST_AddEdgeModFace('city_data', 7, 6,
diff --git a/topology/test/regress/st_addedgenewfaces.sql b/topology/test/regress/st_addedgenewfaces.sql
index 71cfd99..db90018 100644
--- a/topology/test/regress/st_addedgenewfaces.sql
+++ b/topology/test/regress/st_addedgenewfaces.sql
@@ -1,6 +1,6 @@
SELECT topology.ST_AddEdgeNewFaces('city_data', 7, 6,
diff --git a/topology/test/regress/st_addisonode.sql b/topology/test/regress/st_addisonode.sql
index 5f97654..4413876 100644
--- a/topology/test/regress/st_addisonode.sql
+++ b/topology/test/regress/st_addisonode.sql
@@ -3,7 +3,7 @@ set client_min_messages to WARNING;
-- Usual city_data input
-- NULL exceptions
select ST_AddIsoNode(NULL, 0, 'POINT(1 4)');
diff --git a/topology/test/regress/st_changeedgegeom.sql b/topology/test/regress/st_changeedgegeom.sql
index b86aab2..bc18878 100644
--- a/topology/test/regress/st_changeedgegeom.sql
+++ b/topology/test/regress/st_changeedgegeom.sql
@@ -1,6 +1,6 @@
-- good one
SELECT 'T1', topology.ST_ChangeEdgeGeom('city_data', 25,
diff --git a/topology/test/regress/st_modedgeheal.sql b/topology/test/regress/st_modedgeheal.sql
index 2e86ece..8322992 100644
--- a/topology/test/regress/st_modedgeheal.sql
+++ b/topology/test/regress/st_modedgeheal.sql
@@ -2,7 +2,7 @@
-- Import city_data
SELECT topology.ST_ModEdgeHeal('city_data', 1, null);
SELECT topology.ST_ModEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_modedgesplit.sql b/topology/test/regress/st_modedgesplit.sql
index c813d14..98310fe 100644
--- a/topology/test/regress/st_modedgesplit.sql
+++ b/topology/test/regress/st_modedgesplit.sql
@@ -3,7 +3,7 @@
-- Import city_data
-- Save max node id
select 'node'::text as what, max(node_id) INTO city_data.limits FROM city_data.node;
diff --git a/topology/test/regress/st_newedgeheal.sql b/topology/test/regress/st_newedgeheal.sql
index c2b74dd..e49979f 100644
--- a/topology/test/regress/st_newedgeheal.sql
+++ b/topology/test/regress/st_newedgeheal.sql
@@ -2,7 +2,7 @@
-- Import city_data
SELECT topology.ST_NewEdgeHeal('city_data', 1, null);
SELECT topology.ST_NewEdgeHeal('city_data', null, 1);
diff --git a/topology/test/regress/st_newedgessplit.sql b/topology/test/regress/st_newedgessplit.sql
index 6cedc97..abaeafd 100644
--- a/topology/test/regress/st_newedgessplit.sql
+++ b/topology/test/regress/st_newedgessplit.sql
@@ -3,7 +3,7 @@
-- Import city_data
-- Save max node id
diff --git a/topology/test/regress/st_remedgemodface.sql b/topology/test/regress/st_remedgemodface.sql
index 101b475..a8ac674 100644
--- a/topology/test/regress/st_remedgemodface.sql
+++ b/topology/test/regress/st_remedgemodface.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Utility functions for the test {
@@ -375,9 +375,9 @@ SELECT topology.DropTopology('city_data');
-- Import city_data
-\i cache_geometries.sql
+\i ../cache_geometries.sql
-- A city_street is defined by edge 3, can't drop
SELECT '*RM(3)', topology.ST_RemEdgeModFace('city_data', 3);
diff --git a/topology/test/regress/st_remedgenewface.sql b/topology/test/regress/st_remedgenewface.sql
index 90cf30b..c5f5413 100644
--- a/topology/test/regress/st_remedgenewface.sql
+++ b/topology/test/regress/st_remedgenewface.sql
@@ -2,7 +2,7 @@
-- Import city_data
-- Import city_data
SELECT '*RN(3)', topology.ST_RemEdgeNewFace('city_data', 3);
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index 74de66e..03d3d00 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -1,7 +1,7 @@
-- Save max node id
diff --git a/topology/test/regress/topogeo_addpoint.sql b/topology/test/regress/topogeo_addpoint.sql
index b7c4f92..3f7cd3e 100644
--- a/topology/test/regress/topogeo_addpoint.sql
+++ b/topology/test/regress/topogeo_addpoint.sql
@@ -1,7 +1,7 @@
-- Invalid calls
SELECT 'invalid', TopoGeo_addPoint('city_data', 'LINESTRING(36 26, 38 30)');
diff --git a/topology/test/regress/topogeo_addpolygon.sql b/topology/test/regress/topogeo_addpolygon.sql
index f21379f..68863b0 100644
--- a/topology/test/regress/topogeo_addpolygon.sql
+++ b/topology/test/regress/topogeo_addpolygon.sql
@@ -1,7 +1,7 @@
-- Save max node,edge and face ids
diff --git a/topology/test/regress/topogeometry_type.sql b/topology/test/regress/topogeometry_type.sql
index 05c21fe..4da8a31 100644
--- a/topology/test/regress/topogeometry_type.sql
+++ b/topology/test/regress/topogeometry_type.sql
@@ -1,9 +1,9 @@
-\i hierarchy.sql
SELECT DISTINCT 'GeometryType(traffic_signs)',
geometrytype(feature) FROM features.traffic_signs;
diff --git a/topology/test/regress/topojson.sql b/topology/test/regress/topojson.sql
index 6a0aad4..e5ccf14 100644
--- a/topology/test/regress/topojson.sql
+++ b/topology/test/regress/topojson.sql
@@ -1,8 +1,8 @@
-\i hierarchy.sql
-- This edges perturbate the topology so that walking around the boundaries
-- of P1 and P2 may require walking on some of them
Summary of changes:
regress/run_test.pl | 6 ++++--
topology/test/regress/cleartopogeom.sql | 4 ++--
topology/test/regress/copytopology.sql | 6 +++---
topology/test/regress/getnodeedges.sql | 2 +-
topology/test/regress/getringedges.sql | 2 +-
topology/test/regress/gettopogeomelements.sql | 4 ++--
topology/test/regress/gml.sql | 6 +++---
topology/test/regress/legacy_invalid.sql | 2 +-
topology/test/regress/legacy_predicate.sql | 10 +++++-----
topology/test/regress/legacy_query.sql | 10 +++++-----
topology/test/regress/legacy_validate.sql | 4 ++--
topology/test/regress/st_addedgemodface.sql | 2 +-
topology/test/regress/st_addedgenewfaces.sql | 2 +-
topology/test/regress/st_addisonode.sql | 2 +-
topology/test/regress/st_changeedgegeom.sql | 2 +-
topology/test/regress/st_modedgeheal.sql | 2 +-
topology/test/regress/st_modedgesplit.sql | 2 +-
topology/test/regress/st_newedgeheal.sql | 2 +-
topology/test/regress/st_newedgessplit.sql | 2 +-
topology/test/regress/st_remedgemodface.sql | 8 ++++----
topology/test/regress/st_remedgenewface.sql | 8 ++++----
topology/test/regress/topogeo_addlinestring.sql | 2 +-
topology/test/regress/topogeo_addpoint.sql | 2 +-
topology/test/regress/topogeo_addpolygon.sql | 2 +-
topology/test/regress/topogeometry_type.sql | 8 ++++----
topology/test/regress/topojson.sql | 6 +++---
26 files changed, 55 insertions(+), 53 deletions(-)
hooks/post-receive
