[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-103-g88d70f6
git at osgeo.org
git at osgeo.org
Wed Oct 28 14:34:32 PDT 2020
the project "PostGIS".
via 88d70f63fdfc250d5cf64b41c5705e0b0c3ef747 (commit)
via 63a3c143c03fdd21b0967ff49a1bbee94a954ea2 (commit)
from 47e75c49349ad1b89a9b93605cfe98211744180f (commit)
revisions in full, below.
commit 88d70f63fdfc250d5cf64b41c5705e0b0c3ef747
Merge: 63a3c14 47e75c4
Author: Regina Obe <lr at pcorp.us>
Date: Wed Oct 28 17:34:24 2020 -0400
Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis
commit 63a3c143c03fdd21b0967ff49a1bbee94a954ea2
Date: Wed Oct 28 17:34:00 2020 -0400
Add cross reference for &&, ST_Intersects, ST_Extent to each other. Closes #4593 for PostGIS 3.1.0
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index aa4f0b3..6b01777 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -395,7 +395,7 @@ SELECT ST_SetSRID(ST_Extent(the_geom),2249) as bextent FROM sometable;
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_AsEWKT" />, <xref linkend="ST_3DExtent" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" /></para>
+ <para><xref linkend="geometry_overlaps" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_3DExtent" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" /></para>
</refsection>
</refentry>
diff --git a/doc/reference_operator.xml b/doc/reference_operator.xml
index 6b0499b..0ae2539 100644
--- a/doc/reference_operator.xml
+++ b/doc/reference_operator.xml
@@ -50,21 +50,21 @@
</funcsynopsis>
</refsynopsisdiv>
- <refsection>
- <title>Description</title>
+ <refsection>
+ <title>Description</title>
- <para>The <varname>&&</varname> operator returns <varname>TRUE</varname> if the 2D bounding box of geometry A intersects the 2D bounding box of geometry B.</para>
+ <para>The <varname>&&</varname> operator returns <varname>TRUE</varname> if the 2D bounding box of geometry A intersects the 2D bounding box of geometry B.</para>
- <note><para>This operand will make use of any indexes that may be available on the
- geometries.</para></note>
+ <note><para>This operand will make use of any indexes that may be available on the
+ geometries.</para></note>
- <para>Enhanced: 2.0.0 support for Polyhedral surfaces was introduced.</para>
- <para>Availability: 1.5.0 support for geography was introduced.</para>
- <para>&curve_support;</para>
- <para>&P_support;</para>
- </refsection>
+ <para>Enhanced: 2.0.0 support for Polyhedral surfaces was introduced.</para>
+ <para>Availability: 1.5.0 support for geography was introduced.</para>
+ <para>&curve_support;</para>
+ <para>&P_support;</para>
+ </refsection>
- <refsection>
+ <refsection>
<title>Examples</title>
<programlisting>SELECT tbl1.column1, tbl2.column1, tbl1.column2 && tbl2.column2 AS overlaps
@@ -86,12 +86,15 @@ FROM ( VALUES
<para>
+ <xref linkend="ST_Intersects" />,
+ <xref linkend="ST_Extent" />,
<xref linkend="ST_Geometry_Overabove" />,
<xref linkend="ST_Geometry_Overright" />,
<xref linkend="ST_Geometry_Overbelow" />,
<xref linkend="ST_Geometry_Overleft" />,
<xref linkend="ST_Geometry_Contain" />,
- <xref linkend="ST_Geometry_Contained" /></para>
+ <xref linkend="ST_Geometry_Contained" />
+ </para>
</refsection>
</refentry>
diff --git a/doc/reference_relationship.xml b/doc/reference_relationship.xml
index 160e76c..7c75052 100644
--- a/doc/reference_relationship.xml
+++ b/doc/reference_relationship.xml
@@ -1041,7 +1041,7 @@ SELECT ST_Equals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
<refname>ST_Intersects</refname>
<refpurpose>Returns TRUE if the Geometries/Geography "spatially
- intersect in 2D" - (share any portion of space) and FALSE if they don't (they are Disjoint).
+ intersects in 2D" - (share any portion of space) and FALSE if they don't (they are Disjoint).
For geography tolerance is 0.00001 meters (so any points that close are considered to intersect)
</refpurpose>
</refnamediv>
@@ -1141,7 +1141,7 @@ t
</refsection>
<refsection>
- <para> <xref linkend="ST_3DIntersects" />, <xref linkend="ST_Disjoint"/></para>
+ <para><xref linkend="geometry_overlaps" />, <xref linkend="ST_3DIntersects" />, <xref linkend="ST_Disjoint"/></para>
</refsection>
</refentry>
@@ -1205,7 +1205,7 @@ SELECT ST_OrderingEquals(ST_Reverse(ST_GeomFromText('LINESTRING(0 0, 10 10)')),
</refsection>
<refsection>
- <para><xref linkend="ST_Equals"/>, <xref linkend="ST_Reverse"/></para>
+ <para><xref linkend="geometry_overlaps" />, <xref linkend="ST_Equals"/>, <xref linkend="ST_Reverse"/></para>
</refsection>
</refentry>
Summary of changes:
doc/reference_bbox.xml | 2 +-
doc/reference_operator.xml | 27 +++++++++++++++------------
doc/reference_relationship.xml | 6 +++---
3 files changed, 19 insertions(+), 16 deletions(-)
hooks/post-receive
