[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-104-gdf6924e
Wed Oct 28 15:00:48 PDT 2020
the project "PostGIS".
       via  df6924e7ff4f470351934b81e66f3c81dd6be6ad (commit)
      from  88d70f63fdfc250d5cf64b41c5705e0b0c3ef747 (commit)
revisions in full, below.
commit df6924e7ff4f470351934b81e66f3c81dd6be6ad
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Oct 28 22:59:00 2020 +0100
    Fix sfcgal.so dependency on postgis_revision.h
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 517209c..68849fc 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -79,7 +79,13 @@ SHLIB_LINK := $(SHLIB_LINK_F) $(SHLIB_LINK)
 PG_CONFIG := @PG_CONFIG@
 PGXS := @PGXS@
-$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h
+# Make all PostGIS objects depend upon liblwgeom, so that if an underlying
+# change is made, a PostGIS rebuild is triggered.
+# Also they are all dependent on postgis_config.h
+# and thus postgis_revision.h
+$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
 # Note: we specify liblwgeom.a directly in SHLIB_LINK rather than using
 # -L... -l options to prevent issues with some platforms trying to link
@@ -130,14 +136,6 @@ ifeq ($(REGRESS),1)
 	datamoduledir=contrib/postgis
 endif
-# Make all PostGIS objects depend upon liblwgeom, so that if an underlying
-# change is made, a PostGIS rebuild is triggered.
-# Also they are all dependent on postgis_config.h
-# and thus postgis_revision.h
-$(PG_OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
 # Borrow the $libdir substitution from PGXS but customise by running the preprocessor
 # and adding the version number
 # replace @extschema at . with nothing, this is only used as placeholder for extension install
Summary of changes:
 sfcgal/Makefile.in | 16 +++++++---------
 1 file changed, 7 insertions(+), 9 deletions(-)
hooks/post-receive
