[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-105-g3af1395
git at osgeo.org
git at osgeo.org
Wed Oct 28 15:18:38 PDT 2020
the project "PostGIS".
via 3af1395de1890910fb98e6c59c49c210a806da8a (commit)
from df6924e7ff4f470351934b81e66f3c81dd6be6ad (commit)
revisions in full, below.
commit 3af1395de1890910fb98e6c59c49c210a806da8a
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Oct 28 23:17:11 2020 +0100
Fix sfcgal sql scripts dependency on postgis_revision.h
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 68849fc..1aecd2b 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -87,6 +87,10 @@ PGXS := @PGXS@
$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
+# SQL objects are also dependent on postgis_config.h for PostgreSQL
+# version
+$(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
# Note: we specify liblwgeom.a directly in SHLIB_LINK rather than using
# -L... -l options to prevent issues with some platforms trying to link
# to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
Summary of changes:
sfcgal/Makefile.in | 4 ++++
1 file changed, 4 insertions(+)
hooks/post-receive
