[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-107-gd304bad
git at osgeo.org
git at osgeo.org
Wed Oct 28 16:11:05 PDT 2020
the project "PostGIS".
via d304bada1c7fed6b2f3f20a0f417ec26ebe8ad42 (commit)
via 52e0c2f4b369c08f6920e42698951133d787ce24 (commit)
from 3af1395de1890910fb98e6c59c49c210a806da8a (commit)
revisions in full, below.
commit d304bada1c7fed6b2f3f20a0f417ec26ebe8ad42
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Oct 29 00:05:17 2020 +0100
Remove unused variable
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index be788f5..59eb918 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -39,13 +39,15 @@ SQL_built=postgis.sql uninstall_postgis.sql postgis_upgrade.sql legacy.sql unins
DATA=../spatial_ref_sys.sql
# SQL objects (files requiring pre-processing)
-SQL_objs=postgis.sql legacy.sql legacy_minimal.sql
+SQL_OBJS = \
+ postgis.sql \
+ legacy.sql \
+ legacy_minimal.sql
GEOM_BACKEND_OBJ = lwgeom_geos.o
BACKEND_OBJ=$(GEOM_BACKEND_OBJ)
DATA_built=$(SQL_built)
-SQL_OBJS=$(SQL_objs)
ifeq (@HAVE_SPGIST@,yes)
SPGIST_OBJ= gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
commit 52e0c2f4b369c08f6920e42698951133d787ce24
Date: Thu Oct 29 00:04:57 2020 +0100
Fix sfcgal_upgrade.sql build
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 1aecd2b..9455981 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -42,11 +42,7 @@ SQLPP = @SQLPP@
SQL_OBJS = \
- sfcgal.sql \
- sfcgal_upgrade.sql.in \
- sfcgal_upgrade.sql \
- sfcgal_after_upgrade.sql \
- sfcgal_before_upgrade.sql
+ sfcgal.sql
# Objects to build using PGXS
@@ -68,9 +64,6 @@ PG_CPPFLAGS += @SFCGAL_CPPFLAGS@
SHLIB_LINK_F += @SFCGAL_LDFLAGS@
endif
-# Set PERL _after_ the include of PGXS
-PERL=@PERL@
# This is to workaround a bug in PGXS 8.4 win32 link line,
# see http://trac.osgeo.org/postgis/ticket/1158#comment:57
SHLIB_LINK := $(SHLIB_LINK_F) $(SHLIB_LINK)
@@ -79,18 +72,6 @@ SHLIB_LINK := $(SHLIB_LINK_F) $(SHLIB_LINK)
PG_CONFIG := @PG_CONFIG@
PGXS := @PGXS@
-# Make all PostGIS objects depend upon liblwgeom, so that if an underlying
-# change is made, a PostGIS rebuild is triggered.
-# Also they are all dependent on postgis_config.h
-# and thus postgis_revision.h
-$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
-# SQL objects are also dependent on postgis_config.h for PostgreSQL
-# version
-$(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
# Note: we specify liblwgeom.a directly in SHLIB_LINK rather than using
# -L... -l options to prevent issues with some platforms trying to link
# to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
@@ -107,7 +88,11 @@ endif
# Extra files to remove during 'make clean'
EXTRA_CLEAN=$(SQL_OBJS) \
- uninstall_sfcgal.sql
+ uninstall_sfcgal.sql \
+ sfcgal_upgrade.sql.in \
+ sfcgal_upgrade.sql \
+ sfcgal_after_upgrade.sql \
+ sfcgal_before_upgrade.sql
# PGXS information
@@ -140,6 +125,19 @@ ifeq ($(REGRESS),1)
datamoduledir=contrib/postgis
endif
+# Make all PostGIS objects depend upon liblwgeom, so that if an underlying
+# change is made, a PostGIS rebuild is triggered.
+# Also they are all dependent on postgis_config.h
+# and thus postgis_revision.h
+$(OBJS): ../liblwgeom/.libs/liblwgeom.a ../libpgcommon/libpgcommon.a ../postgis_config.h ../postgis_revision.h
+# SQL objects are also dependent on postgis_config.h for PostgreSQL
+# version
+$(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
# Borrow the $libdir substitution from PGXS but customise by running the preprocessor
# and adding the version number
# replace @extschema at . with nothing, this is only used as placeholder for extension install
Summary of changes:
postgis/Makefile.in | 6 ++++--
sfcgal/Makefile.in | 40 +++++++++++++++++++---------------------
2 files changed, 23 insertions(+), 23 deletions(-)
hooks/post-receive
