[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-109-g8d3cf31
git at osgeo.org
git at osgeo.org
Wed Oct 28 17:04:32 PDT 2020
the project "PostGIS".
via 8d3cf31a3a13c0ce2e4d5025389d6a023dd63848 (commit)
from ac0351817888d8f45911de1b60c21a461acf9507 (commit)
revisions in full, below.
commit 8d3cf31a3a13c0ce2e4d5025389d6a023dd63848
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Oct 28 19:16:14 2020 +0100
Refactor autotools configuration for regression tests
- Runs sfcgal tests in the same db with core tests
- Allow running loader/dumper tests in isolation
Closes #4207
diff --git a/.gitignore b/.gitignore
index 5405e32..e48169d 100644
--- a/.gitignore
+++ b/.gitignore
@@ -148,6 +148,9 @@ raster/test/regress/loader/TiledAutoSkipNoData.tif
regress/00-regress-install/
regress/Makefile
regress/core/Makefile
+regress/core/tests.mk
+regress/dumper/Makefile
+regress/loader/Makefile
regress/sfcgal/Makefile
regress/postgis.sql
regress/postgis_garden_result.txt
diff --git a/configure.ac b/configure.ac
index 4c7d412..587d3a4 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1595,6 +1595,9 @@ AC_OUTPUT([GNUmakefile
topology/test/Makefile
regress/Makefile
+ regress/core/tests.mk
+ regress/dumper/Makefile
+ regress/loader/Makefile
doc/Makefile
doc/Makefile.comments
diff --git a/regress/Makefile.in b/regress/Makefile.in
index 7fe9bae..66d53df 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -18,6 +18,8 @@ POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
POSTGIS_MICRO_VERSION=@POSTGIS_MICRO_VERSION@
+topsrcdir = $(realpath ../)
# Where we put our regression installation
ifeq ($(MINGWBUILD),1)
srcdir=$(shell bash -c "pwd -W")
@@ -39,26 +41,31 @@ export PATH
all install uninstall:
-check: check-regress
+check-regress: staged-install
+check-regress: check
check-unit:
-check-regress: staged-install
- $(MAKE) -C core check
+include core/tests.mk
+include loader/tests.mk
+include dumper/tests.mk
ifeq ($(HAVE_SFCGAL),yes)
- $(MAKE) -C sfcgal check
+ override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
+ include sfcgal/tests.mk
endif
+include runtest.mk
clean:
- $(MAKE) -C core $@
- $(MAKE) -C sfcgal $@
rm -rf $(REGRESS_INSTALLDIR)
rm -f postgis_garden_result.txt
distclean: clean
rm -f Makefile
+ rm -f core/Makefile
+ rm -f loader/Makefile
+ rm -f dumper/Makefile
+ rm -f sfcgal/Makefile
staged-install-sfcgal:
@if test x"@SFCGAL@" != "x"; then \
diff --git a/regress/core/Makefile.in b/regress/core/Makefile.in
index fd9529f..5d24128 100644
--- a/regress/core/Makefile.in
+++ b/regress/core/Makefile.in
@@ -3,9 +3,7 @@
# * PostGIS - Spatial Types for PostgreSQL
# * http://postgis.net
-# * Copyright (C) 2011-2012 Sandro Santilli <strk at kbt.io>
-# * Copyright (C) 2009-2011 Paul Ramsey <pramsey at cleverelephant.ca>
-# * Copyright (C) 2008-2009 Mark Cave-Ayland
+# * Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
# * This is free software; you can redistribute and/or modify it under
# * the terms of the GNU General Public Licence. See the COPYING file.
@@ -13,238 +11,8 @@
PERL=@PERL@
-TMPDIR?=/tmp
-POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
-POSTGIS_GEOS_VERSION=@POSTGIS_GEOS_VERSION@
-GEOS_NUMERIC_VERSION=@GEOS_NUMERIC_VERSION@
-POSTGIS_PROJ_VERSION=@POSTGIS_PROJ_VERSION@
-POSTGIS_MAJOR_VERSION=@POSTGIS_MAJOR_VERSION@
-POSTGIS_MINOR_VERSION=@POSTGIS_MINOR_VERSION@
-HAVE_JSON=@HAVE_JSON@
-PROTOC_VERSION=@PROTOC_VERSION@
-HAVE_SPGIST=@HAVE_SPGIST@
-INTERRUPTTESTS=@INTERRUPTTESTS@
+topsrcdir = $(realpath ../../)
-# MingW hack: rather than use PGSQL_BINDIR directly, we change
-# to the directory and then use "pwd" to return the path. This
-# ensures that the returned path is in MSYS format, otherwise
-# colons in drive letters will break PATH.
-PGSQL_BINDIR=$(shell cd "@PGSQL_BINDIR@" && pwd)
-# Put path from pg_config into front of search path
-PATH := $(PGSQL_BINDIR):$(PATH)
-export PATH
-TESTS = \
- ../loader/Point \
- ../loader/PointM \
- ../loader/PointZ \
- ../loader/MultiPoint \
- ../loader/MultiPointM \
- ../loader/MultiPointZ \
- ../loader/Arc \
- ../loader/ArcM \
- ../loader/ArcZ \
- ../loader/Polygon \
- ../loader/PolygonM \
- ../loader/PolygonZ \
- ../loader/TSTPolygon \
- ../loader/TSIPolygon \
- ../loader/TSTIPolygon \
- ../loader/PointWithSchema \
- ../loader/NoTransPoint \
- ../loader/NotReallyMultiPoint \
- ../loader/MultiToSinglePoint \
- ../loader/ReprojectPts \
- ../loader/ReprojectPtsD \
- ../loader/ReprojectPtsGeog \
- ../loader/ReprojectPtsGeogD \
- ../loader/Latin1 \
- ../loader/Latin1-implicit \
- ../loader/mfile \
- ../dumper/mfiledmp \
- ../dumper/literalsrid \
- ../dumper/realtable \
- ../dumper/nullsintable \
- ../dumper/null3d \
- affine \
- bestsrid \
- binary \
- boundary \
- chaikin \
- filterm \
- cluster \
- concave_hull\
- ctors \
- curvetoline \
- dump \
- dumppoints \
- empty \
- estimatedextent \
- forcecurve \
- geography \
- geometric_median \
- hausdorff \
- in_geohash \
- in_gml \
- in_kml \
- in_encodedpolyline \
- iscollection \
- legacy \
- long_xact \
- lwgeom_regress \
- measures \
- minimum_bounding_circle \
- normalize \
- operators \
- orientation \
- out_geometry \
- out_geography \
- polygonize \
- polyhedralsurface \
- postgis_type_name \
- quantize_coordinates \
- regress \
- regress_bdpoly \
- regress_buffer_params \
- regress_gist_index_nd \
- regress_index \
- regress_index_nulls \
- regress_management \
- regress_selectivity \
- regress_lrs \
- regress_ogc \
- regress_ogc_cover \
- regress_ogc_prep \
- regress_proj \
- relate \
- remove_repeated_points \
- removepoint \
- reverse \
- setpoint \
- simplify \
- simplifyvw \
- size \
- snaptogrid \
- split \
- sql-mm-serialize \
- sql-mm-circularstring \
- sql-mm-compoundcurve \
- sql-mm-curvepoly \
- sql-mm-general \
- sql-mm-multicurve \
- sql-mm-multisurface \
- swapordinates \
- summary \
- temporal \
- temporal_knn \
- tickets \
- twkb \
- typmod \
- wkb \
- wkt \
- wmsservers \
- offsetcurve \
- relatematch \
- isvaliddetail \
- sharedpaths \
- snap \
- node \
- unaryunion \
- clean \
- relate_bnr \
- delaunaytriangles \
- clipbybox2d \
- subdivide \
- voronoi \
- regress_brin_index \
- regress_brin_index_3d \
- regress_brin_index_geography \
- minimum_clearance \
- oriented_envelope \
- point_coordinates \
- out_geojson
-# Slow slow tests
-TESTS_SLOW = \
- concave_hull_hard \
- knn_recheck
-ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
- TESTS += \
- computed_columns
-endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 37),1)
- # GEOS-3.7 adds:
- # ST_FrechetDistance
- TESTS += \
- frechet
-endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 38),1)
- # GEOS-3.8 adds stable pointonsurface implementation
- TESTS += \
- geos38
-endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 39),1)
- # GEOS-3.0 adds stable maximuminscribedcircle implementation
- TESTS += \
- geos39 \
- fixedoverlay
-endif
-ifeq ($(INTERRUPTTESTS),yes)
- # Allow CI servers to configure --with-interrupt-tests
- TESTS += \
- interrupt \
- interrupt_relate \
- interrupt_buffer
-endif
-ifeq ($(HAVE_JSON),yes)
- # JSON-C adds:
- # ST_GeomFromGeoJSON()
- TESTS += \
- in_geojson
-endif
-ifeq ($(HAVE_SPGIST),yes)
- TESTS += \
- regress_spgist_index_2d \
- regress_spgist_index_3d \
- regress_spgist_index_nd
-endif
-ifeq (@HAVE_PROTOBUF@,yes)
- # protobuf-c adds:
- # ST_AsMVT, ST_AsGeobuf
- TESTS += \
- mvt \
- mvt_jsonb \
- geobuf
-endif
-all install uninstall:
-distclean: clean
- rm Makefile
-test check:
- $(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS)
- # only run upgrade test if RUNTESTFLAGS was not already doing that
- if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
- $(PERL) ../run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
- fi
-check-long:
- $(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
-clean:
+include tests.mk
+include ../runtest.mk
diff --git a/regress/core/regress.sql b/regress/core/regress.sql
index bb21b97..4babc22 100644
--- a/regress/core/regress.sql
+++ b/regress/core/regress.sql
@@ -333,9 +333,12 @@ DROP table test;
SELECT DISTINCT 'unexpected probin', proname || ':' || probin
FROM pg_proc
WHERE probin like '%postgis%'
- AND regexp_replace(probin, '(rt)?postgis(_[^-]*)?', '') !=
+ AND
+regexp_replace(probin, '(rt)?postgis(_[^-]*)?(-[0-9.])$', '\3')
-SELECT regexp_replace(probin, '(rt)?postgis(_[^-]*)?', '')
+ SELECT
FROM pg_proc WHERE proname = 'postgis_lib_version'
ORDER BY 2;
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
new file mode 100644
index 0000000..db0e5c2
--- /dev/null
+++ b/regress/core/tests.mk.in
@@ -0,0 +1,181 @@
+# * PostGIS - Spatial Types for PostgreSQL
+# * http://postgis.net
+# * Copyright (C) 2011-2020 Sandro Santilli <strk at kbt.io>
+# * Copyright (C) 2009-2011 Paul Ramsey <pramsey at cleverelephant.ca>
+# * Copyright (C) 2008-2009 Mark Cave-Ayland
+# * This is free software; you can redistribute and/or modify it under
+# * the terms of the GNU General Public Licence. See the COPYING file.
+POSTGIS_PGSQL_VERSION=@POSTGIS_PGSQL_VERSION@
+POSTGIS_GEOS_VERSION=@POSTGIS_GEOS_VERSION@
+HAVE_JSON=@HAVE_JSON@
+HAVE_SPGIST=@HAVE_SPGIST@
+INTERRUPTTESTS=@INTERRUPTTESTS@
+current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
+TESTS += \
+ $(topsrcdir)/regress/core/affine \
+ $(topsrcdir)/regress/core/bestsrid \
+ $(topsrcdir)/regress/core/binary \
+ $(topsrcdir)/regress/core/boundary \
+ $(topsrcdir)/regress/core/chaikin \
+ $(topsrcdir)/regress/core/filterm \
+ $(topsrcdir)/regress/core/cluster \
+ $(topsrcdir)/regress/core/concave_hull\
+ $(topsrcdir)/regress/core/ctors \
+ $(topsrcdir)/regress/core/curvetoline \
+ $(topsrcdir)/regress/core/dump \
+ $(topsrcdir)/regress/core/dumppoints \
+ $(topsrcdir)/regress/core/empty \
+ $(topsrcdir)/regress/core/estimatedextent \
+ $(topsrcdir)/regress/core/forcecurve \
+ $(topsrcdir)/regress/core/geography \
+ $(topsrcdir)/regress/core/geometric_median \
+ $(topsrcdir)/regress/core/hausdorff \
+ $(topsrcdir)/regress/core/in_geohash \
+ $(topsrcdir)/regress/core/in_gml \
+ $(topsrcdir)/regress/core/in_kml \
+ $(topsrcdir)/regress/core/in_encodedpolyline \
+ $(topsrcdir)/regress/core/iscollection \
+ $(topsrcdir)/regress/core/legacy \
+ $(topsrcdir)/regress/core/long_xact \
+ $(topsrcdir)/regress/core/lwgeom_regress \
+ $(topsrcdir)/regress/core/measures \
+ $(topsrcdir)/regress/core/minimum_bounding_circle \
+ $(topsrcdir)/regress/core/normalize \
+ $(topsrcdir)/regress/core/operators \
+ $(topsrcdir)/regress/core/orientation \
+ $(topsrcdir)/regress/core/out_geometry \
+ $(topsrcdir)/regress/core/out_geography \
+ $(topsrcdir)/regress/core/polygonize \
+ $(topsrcdir)/regress/core/polyhedralsurface \
+ $(topsrcdir)/regress/core/postgis_type_name \
+ $(topsrcdir)/regress/core/quantize_coordinates \
+ $(topsrcdir)/regress/core/regress \
+ $(topsrcdir)/regress/core/regress_bdpoly \
+ $(topsrcdir)/regress/core/regress_buffer_params \
+ $(topsrcdir)/regress/core/regress_gist_index_nd \
+ $(topsrcdir)/regress/core/regress_index \
+ $(topsrcdir)/regress/core/regress_index_nulls \
+ $(topsrcdir)/regress/core/regress_management \
+ $(topsrcdir)/regress/core/regress_selectivity \
+ $(topsrcdir)/regress/core/regress_lrs \
+ $(topsrcdir)/regress/core/regress_ogc \
+ $(topsrcdir)/regress/core/regress_ogc_cover \
+ $(topsrcdir)/regress/core/regress_ogc_prep \
+ $(topsrcdir)/regress/core/regress_proj \
+ $(topsrcdir)/regress/core/relate \
+ $(topsrcdir)/regress/core/remove_repeated_points \
+ $(topsrcdir)/regress/core/removepoint \
+ $(topsrcdir)/regress/core/reverse \
+ $(topsrcdir)/regress/core/setpoint \
+ $(topsrcdir)/regress/core/simplify \
+ $(topsrcdir)/regress/core/simplifyvw \
+ $(topsrcdir)/regress/core/size \
+ $(topsrcdir)/regress/core/snaptogrid \
+ $(topsrcdir)/regress/core/split \
+ $(topsrcdir)/regress/core/sql-mm-serialize \
+ $(topsrcdir)/regress/core/sql-mm-circularstring \
+ $(topsrcdir)/regress/core/sql-mm-compoundcurve \
+ $(topsrcdir)/regress/core/sql-mm-curvepoly \
+ $(topsrcdir)/regress/core/sql-mm-general \
+ $(topsrcdir)/regress/core/sql-mm-multicurve \
+ $(topsrcdir)/regress/core/sql-mm-multisurface \
+ $(topsrcdir)/regress/core/swapordinates \
+ $(topsrcdir)/regress/core/summary \
+ $(topsrcdir)/regress/core/temporal \
+ $(topsrcdir)/regress/core/temporal_knn \
+ $(topsrcdir)/regress/core/tickets \
+ $(topsrcdir)/regress/core/twkb \
+ $(topsrcdir)/regress/core/typmod \
+ $(topsrcdir)/regress/core/wkb \
+ $(topsrcdir)/regress/core/wkt \
+ $(topsrcdir)/regress/core/wmsservers \
+ $(topsrcdir)/regress/core/offsetcurve \
+ $(topsrcdir)/regress/core/relatematch \
+ $(topsrcdir)/regress/core/isvaliddetail \
+ $(topsrcdir)/regress/core/sharedpaths \
+ $(topsrcdir)/regress/core/snap \
+ $(topsrcdir)/regress/core/node \
+ $(topsrcdir)/regress/core/unaryunion \
+ $(topsrcdir)/regress/core/clean \
+ $(topsrcdir)/regress/core/relate_bnr \
+ $(topsrcdir)/regress/core/delaunaytriangles \
+ $(topsrcdir)/regress/core/clipbybox2d \
+ $(topsrcdir)/regress/core/subdivide \
+ $(topsrcdir)/regress/core/voronoi \
+ $(topsrcdir)/regress/core/regress_brin_index \
+ $(topsrcdir)/regress/core/regress_brin_index_3d \
+ $(topsrcdir)/regress/core/regress_brin_index_geography \
+ $(topsrcdir)/regress/core/minimum_clearance \
+ $(topsrcdir)/regress/core/oriented_envelope \
+ $(topsrcdir)/regress/core/point_coordinates \
+ $(topsrcdir)/regress/core/out_geojson
+# Slow slow tests
+TESTS_SLOW = \
+ $(topsrcdir)/regress/core/concave_hull_hard \
+ $(topsrcdir)/regress/core/knn_recheck
+ifeq ($(shell expr "$(POSTGIS_PGSQL_VERSION)" ">=" 120),1)
+ TESTS += \
+ $(topsrcdir)/regress/core/computed_columns
+endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 37),1)
+ # GEOS-3.7 adds:
+ # ST_FrechetDistance
+ TESTS += \
+ $(topsrcdir)/regress/core/frechet
+endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 38),1)
+ # GEOS-3.8 adds stable pointonsurface implementation
+ TESTS += \
+ $(topsrcdir)/regress/core/geos38
+endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 39),1)
+ # GEOS-3.0 adds stable maximuminscribedcircle implementation
+ TESTS += \
+ $(topsrcdir)/regress/core/geos39 \
+ $(topsrcdir)/regress/core/fixedoverlay
+endif
+ifeq ($(INTERRUPTTESTS),yes)
+ # Allow CI servers to configure --with-interrupt-tests
+ TESTS += \
+ $(topsrcdir)/regress/core/interrupt \
+ $(topsrcdir)/regress/core/interrupt_relate \
+ $(topsrcdir)/regress/core/interrupt_buffer
+endif
+ifeq ($(HAVE_JSON),yes)
+ # JSON-C adds:
+ # ST_GeomFromGeoJSON()
+ TESTS += \
+ $(topsrcdir)/regress/core/in_geojson
+endif
+ifeq ($(HAVE_SPGIST),yes)
+ TESTS += \
+ $(topsrcdir)/regress/core/regress_spgist_index_2d \
+ $(topsrcdir)/regress/core/regress_spgist_index_3d \
+ $(topsrcdir)/regress/core/regress_spgist_index_nd
+endif
+ifeq (@HAVE_PROTOBUF@,yes)
+ # protobuf-c adds:
+ # ST_AsMVT, ST_AsGeobuf
+ TESTS += \
+ $(topsrcdir)/regress/core/mvt \
+ $(topsrcdir)/regress/core/mvt_jsonb \
+ $(topsrcdir)/regress/core/geobuf
+endif
diff --git a/regress/dumper/Makefile.in b/regress/dumper/Makefile.in
index 0000000..5d24128
--- /dev/null
+++ b/regress/dumper/Makefile.in
@@ -0,0 +1,18 @@
+PERL=@PERL@
+include tests.mk
diff --git a/regress/dumper/tests.mk b/regress/dumper/tests.mk
index 0000000..cbc49dd
--- /dev/null
+++ b/regress/dumper/tests.mk
@@ -0,0 +1,18 @@
+TESTS += \
+ $(topsrcdir)/regress/dumper/mfiledmp \
+ $(topsrcdir)/regress/dumper/literalsrid \
+ $(topsrcdir)/regress/dumper/realtable \
+ $(topsrcdir)/regress/dumper/nullsintable \
+ $(topsrcdir)/regress/dumper/null3d
diff --git a/regress/loader/Makefile.in b/regress/loader/Makefile.in
index 0000000..26244d7
--- /dev/null
+++ b/regress/loader/Makefile.in
@@ -0,0 +1,19 @@
+PERL=@PERL@
+include tests.mk
diff --git a/regress/loader/tests.mk b/regress/loader/tests.mk
index 0000000..85031b7
--- /dev/null
+++ b/regress/loader/tests.mk
@@ -0,0 +1,40 @@
+TESTS += \
+ $(topsrcdir)/regress/loader/Point \
+ $(topsrcdir)/regress/loader/PointM \
+ $(topsrcdir)/regress/loader/PointZ \
+ $(topsrcdir)/regress/loader/MultiPoint \
+ $(topsrcdir)/regress/loader/MultiPointM \
+ $(topsrcdir)/regress/loader/MultiPointZ \
+ $(topsrcdir)/regress/loader/Arc \
+ $(topsrcdir)/regress/loader/ArcM \
+ $(topsrcdir)/regress/loader/ArcZ \
+ $(topsrcdir)/regress/loader/Polygon \
+ $(topsrcdir)/regress/loader/PolygonM \
+ $(topsrcdir)/regress/loader/PolygonZ \
+ $(topsrcdir)/regress/loader/TSTPolygon \
+ $(topsrcdir)/regress/loader/TSIPolygon \
+ $(topsrcdir)/regress/loader/TSTIPolygon \
+ $(topsrcdir)/regress/loader/PointWithSchema \
+ $(topsrcdir)/regress/loader/NoTransPoint \
+ $(topsrcdir)/regress/loader/NotReallyMultiPoint \
+ $(topsrcdir)/regress/loader/MultiToSinglePoint \
+ $(topsrcdir)/regress/loader/ReprojectPts \
+ $(topsrcdir)/regress/loader/ReprojectPtsD \
+ $(topsrcdir)/regress/loader/ReprojectPtsGeog \
+ $(topsrcdir)/regress/loader/ReprojectPtsGeogD \
+ $(topsrcdir)/regress/loader/Latin1 \
+ $(topsrcdir)/regress/loader/Latin1-implicit \
+ $(topsrcdir)/regress/loader/mfile
diff --git a/regress/runtest.mk b/regress/runtest.mk
index 0000000..90a4764
--- /dev/null
+++ b/regress/runtest.mk
@@ -0,0 +1,18 @@
+abstopsrcdir := $(realpath $(topsrcdir))
+abssrcdir := $(realpath .)
+TESTS := $(patsubst $(topsrcdir)/%,$(abstopsrcdir)/%,$(TESTS))
+TESTS := $(patsubst $(abssrcdir)/%,./%,$(TESTS))
+check:
+ $(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS)
+ # only run upgrade test if RUNTESTFLAGS was not already doing that
+ if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
+ $(PERL) $(topsrcdir)/regress/run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+ fi
+check-long:
+ $(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
diff --git a/regress/sfcgal/Makefile.in b/regress/sfcgal/Makefile.in
index 3c1aa0f..00bdc77 100644
--- a/regress/sfcgal/Makefile.in
+++ b/regress/sfcgal/Makefile.in
@@ -3,9 +3,7 @@
@@ -13,45 +11,10 @@
PERL=@PERL@
-TMPDIR?=/tmp
-HAVE_SFCGAL=@HAVE_SFCGAL@
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
-ifeq ($(HAVE_SFCGAL),yes)
-export PATH
-TESTS = \
- regress_sfcgal \
- approximatemedialaxis.sql
-test check:
- $(PERL) ../run_test.pl --sfcgal $(RUNTESTFLAGS) $(TESTS)
- $(PERL) ../run_test.pl --sfcgal --upgrade $(RUNTESTFLAGS) $(TESTS); \
- fi
-else
-check:
-endif # HAVE_SFCGAL
-distclean: clean
- rm Makefile
-clean:
+include tests.mk
diff --git a/regress/sfcgal/tests.mk b/regress/sfcgal/tests.mk
index 0000000..c2a7ab7
--- /dev/null
+++ b/regress/sfcgal/tests.mk
@@ -0,0 +1,16 @@
+TESTS += \
+ $(topsrcdir)/regress/sfcgal/regress_sfcgal \
+ $(topsrcdir)/regress/sfcgal/approximatemedialaxis.sql
Summary of changes:
.gitignore | 3 +
configure.ac | 3 +
regress/Makefile.in | 23 +-
regress/core/Makefile.in | 240 +--------------------
regress/core/regress.sql | 7 +-
regress/core/tests.mk.in | 181 ++++++++++++++++
{libpgcommon/cunit => regress/dumper}/Makefile.in | 11 +-
.../cunit/Makefile.in => regress/dumper/tests.mk | 13 +-
{libpgcommon/cunit => regress/loader}/Makefile.in | 12 +-
regress/loader/tests.mk | 40 ++++
regress/runtest.mk | 18 ++
regress/sfcgal/Makefile.in | 47 +---
.../cunit/Makefile.in => regress/sfcgal/tests.mk | 9 +-
13 files changed, 302 insertions(+), 305 deletions(-)
create mode 100644 regress/core/tests.mk.in
copy {libpgcommon/cunit => regress/dumper}/Makefile.in (72%)
copy libpgcommon/cunit/Makefile.in => regress/dumper/tests.mk (57%)
copy {libpgcommon/cunit => regress/loader}/Makefile.in (72%)
create mode 100644 regress/loader/tests.mk
create mode 100644 regress/runtest.mk
copy libpgcommon/cunit/Makefile.in => regress/sfcgal/tests.mk (68%)
hooks/post-receive
