[postgis-tickets] [PostGIS] #4778: regression failure on SFCGAL
trac at osgeo.org
Thu Oct 29 03:09:27 PDT 2020
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.0
Component: build/upgrade/install | Version: 2.5.x
Keywords: |
I just started getting this error and I see it on winnie too
https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/11260/consoleFull
./core/regress .. failed (diff expected obtained:
/projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_38_diff)
--- ./core/regress_expected 2020-10-29 00:20:36.459427500 -0400
+++ /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_38_out
2020-10-29 00:37:46.409980300 -0400
@@ -231,3 +231,21 @@
314|676
315|0
316|t|LINESTRING(40 8.660254037844387,35 8.660254037844387)
+unexpected
probin|postgis_sfcgal_noop:E:/jenkins/postgis/branches/3.1/regress/00
-regress-install/lib/postgis_sfcgal-3.1
+unexpected
probin|postgis_sfcgal_version:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_3darea:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected
probin|st_3ddifference:E:/jenkins/postgis/branches/3.1/regress/00-regress-
+unexpected
probin|st_3dintersection:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_3dunion:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected
probin|st_approximatemedialaxis:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected
probin|st_constraineddelaunaytriangles:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_extrude:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_forcelhr:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_isplanar:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_issolid:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_makesolid:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected
probin|st_minkowskisum:E:/jenkins/postgis/branches/3.1/regress/00-regress-
+unexpected
probin|st_orientation:E:/jenkins/postgis/branches/3.1/regress/00-regress-
+unexpected
probin|st_straightskeleton:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_tesselate:E:/jenkins/postgis/branches/3.1/regress/00
+unexpected probin|st_volume:E:/jenkins/postgis/branches/3.1/regress/00
Not sure why it is not happening on other bots so might be mingw specific.
I assume it's one of strk's SFCGAL script changes yesterday at fault.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4778>
