[postgis-tickets] [PostGIS] #4684: concurrent topology construction routine may result in invalid topology
trac at osgeo.org
Wed Aug 4 14:59:18 PDT 2021
Reporter: laopsahl | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.4
Component: topology | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
I just learnt that SERIALIZABLE tracking is "pessimistic", that is it may
give false conflicts (error out more than needed). This may result in
actually slower performance than forced serialization via locks. A test
running 16 concurrent transactions each adding a polygon to a topology
completes in 1 second when serialized while can take 10 times as much when
using SERIALIZABLE TRANSACTION ISOLATION LEVEL and re-trying after
sleeping for a random amount of time up to 1 second. Some transactions are
re-attempted up to 10 times before succeeding:
[strk at c19:/usr/local/src/postgis/postgis(topology-advisory-lock)] time
topology/test/check_multiprocess_topology_population.sh 2>&1 | grep
WARNING
WARNING: 15917 succeeded on attempt 1
WARNING: 15950 succeeded on attempt 1
WARNING: 16045 succeeded on attempt 1
WARNING: 16046 succeeded on attempt 2
WARNING: 16025 succeeded on attempt 3
WARNING: 16040 succeeded on attempt 3
WARNING: 15940 succeeded on attempt 4
WARNING: 15994 succeeded on attempt 4
WARNING: 16000 succeeded on attempt 4
WARNING: 16005 succeeded on attempt 6
WARNING: 16011 succeeded on attempt 5
WARNING: 16044 succeeded on attempt 6
WARNING: 15924 succeeded on attempt 6
WARNING: 15999 succeeded on attempt 8
WARNING: 15996 succeeded on attempt 9
WARNING: 16028 succeeded on attempt 9
real 0m5.392s
user 0m0.729s
sys 0m0.168s
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4684#comment:31>
