[postgis-tickets] [PostGIS] #4966: ST_GetFaceGeometry slow with faces with many holes
trac at osgeo.org
Wed Aug 11 08:06:16 PDT 2021
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: main
Keywords: |
In the wild I'm facing a face (no pun intended) with 7100 holes (9295
edges) which takes 1.5 seconds to come out from ST_GetFaceGeometry.
I've observed that ST_Polygonize(edge.geom) takes 0.5 seconds so it looks
like ST_BuildArea is making GetFaceGeometry take 3 times as much as
needed, at the bare minimum.
I guess we could assume topologies are valid and thus not bother doing
what ST_BuildArea does to try at building areas, and rely to simply
building rings and expect a single shell to exist, and consider all the
others "holes".
See also #4680 for an idea to implement this internally.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4966>
