[postgis-tickets] [PostGIS] #4575: GRANT select on topology metadata tables to public
PostGIS trac at osgeo.org
Wed Aug 11 22:04:59 PDT 2021
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  reopened
  Priority:  medium    |  Milestone:  PostGIS 3.2.0
 Component:  topology  |    Version:  main
Resolution:            |   Keywords:
Comment (by laopsahl):
 The most important is select because it's a lot of used cases where we
 only need select.
 But it is strange that a user can create a table with geometry column and
 and not topology column, seen from a user perspective so I think you
 should allow public  access to increment sequence.
 By the way why are these tables located in the topology schema and not in
 public as for instance public.geometry_columns is ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4575#comment:11>
