[postgis-tickets] [PostGIS] #4962: Adding a linestring to the topology can load topology multiple times
trac at osgeo.org
Thu Aug 12 11:31:38 PDT 2021
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: main
Resolution: fixed | Keywords:
Comment (by strk):
I'm reopening this because the choice of using lw_segment_side to
determine the side the query point falls on the closest edge was WRONG and
produces invalid results. I'll have to add a regress test for this case
and find another solution.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4962#comment:3>
