[postgis-tickets] [PostGIS] #4963: PostGIS 2.5 compile fail on windows (mingw64)
trac at osgeo.org
Sun Aug 15 09:37:29 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.6
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
okay it's not just winnie. Dronie 9.6 is having the same issue:
https://dronie.osgeo.org/postgis/postgis/2041/1/2
/local/include -I.. -c -o cu_geodetic.o cu_geodetic.c
gcc -O0 -Wall -fno-omit-frame-pointer -Werror -Wall -Wmissing-prototypes
-I/usr/local/include -I.. -c -o cu_geos.o cu_geos.c
-I/usr/local/include -I.. -c -o cu_geos_cluster.o cu_geos_cluster.c
-I/usr/local/include -I.. -c -o cu_tree.o cu_tree.c
-I/usr/local/include -I.. -c -o cu_measures.o cu_measures.c
cu_measures.c: In function 'test_mindistance2d_tolerance':
cu_measures.c:209:71: error: macro "DIST2DTEST" passed 4 arguments, but
takes just 3
"POINT(5433865 8243495)", 2271704.2698450615, default_accepted_error);
cu_measures.c:207:2: error: 'DIST2DTEST' undeclared (first use in this
function)
DIST2DTEST(
cu_measures.c:207:2: note: each undeclared identifier is reported only
once for each function it appears in
Makefile:98: recipe for target 'cu_measures.o' failed
make[2]: Leaving directory '/drone/src/liblwgeom/cunit'
make[2]: *** [cu_measures.o] Error 1
Makefile:204: recipe for target 'check' failed
make[1]: Leaving directory '/drone/src/liblwgeom'
make[1]: *** [check] Error 2
make: *** [check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4963#comment:1>
