[postgis-tickets] [PostGIS] #4963: PostGIS 2.5 compile fails DIST2DTEST - GEOS < 3.9? (was: PostGIS 2.5 compile fail on windows (mingw64) and dronie)
trac at osgeo.org
Sun Aug 15 09:42:22 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.6
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
Okay I have a suspicion this fails on all bots running geos < 3.9
Debbie is having the same issue too:
https://debbie.postgis.net/job/PostGIS_Regress/17356/consoleFull
00:57:23 -------------- Dependencies --------------
00:57:23 GEOS config:
/var/lib/jenkins/workspace/geos/rel-3.7w64/bin/geos-config
00:57:23 GEOS version: 3.7.4dev
00:57:23 GDAL config:
/var/lib/jenkins/workspace/gdal/rel-2.4w64/bin/gdal-config
00:57:23 GDAL version: 2.4.4
00:57:23 SFCGAL config: /usr/bin/sfcgal-config
00:57:23 SFCGAL version: 1.3.8
00:57:23 PostgreSQL config:
/var/lib/jenkins/workspace/pg/rel/pg9.5w64/bin/pg_config
00:57:23 PostgreSQL version: PostgreSQL 9.5.25
00:57:23 PROJ4 version: 72
00:57:23 Libxml2 config: /usr/bin/xml2-config
00:57:23 Libxml2 version: 2.9.12
00:57:23 JSON-C support: yes
00:57:23 protobuf-c support: yes
00:57:23 protobuf-c version: 1003003
00:57:23 PCRE support: no
00:57:23 Perl: /usr/bin/perl
00:57:23
00:57:23 --------------- Extensions ---------------
01:00:07 cu_measures.c: In function ‘test_mindistance2d_tolerance’:
01:00:07 cu_measures.c:209:71: error: macro "DIST2DTEST" passed 4
arguments, but takes just 3
01:00:07 209 | "POINT(5433865 8243495)", 2271704.2698450615,
default_accepted_error);
01:00:07 |
01:00:07 cu_measures.c:33: note: macro "DIST2DTEST" defined here
01:00:07 33 | #define DIST2DTEST(str1, str2, res) \
01:00:07 |
01:00:07 cu_measures.c:207:2: error: ‘DIST2DTEST’ undeclared (first use in
this function); did you mean ‘DISTPTS’?
01:00:07 207 | DIST2DTEST(
01:00:07 | ^~~~~~~~~~
01:00:07 | DISTPTS
01:00:07 cu_measures.c:207:2: note: each undeclared identifier is reported
only once for each function it appears in
01:00:07 make[2]: *** [Makefile:98: cu_measures.o] Error 1
01:00:07 make[2]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.5/liblwgeom/cunit'
01:00:07 make[1]: *** [Makefile:204: check] Error 2
01:00:07 make[1]: Leaving directory
'/var/lib/jenkins/workspace/postgis/branches/2.5/liblwgeom'
01:00:07 make: *** [GNUmakefile:16: check] Error 1
01:00:07 Build step 'Execute shell' marked build as failure
01:00:07 Triggering a new build of PostgreSQL stop
01:00:07 Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4963#comment:3>
