[postgis-tickets] [PostGIS] #4969: gitlab ci failing on PostGIS 2.5 tickets regress - testing ST_OrientedEnvelope
PostGIS trac at osgeo.org
Sun Aug 15 15:03:55 PDT 2021
ST_OrientedEnvelope
 Reporter:  robe     |      Owner:  robe
     Type:  defect   |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 2.5.6
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 This is a little weird.
 -------------- Compiler Info -------------
   C compiler:           gcc -Wall -fno-omit-frame-pointer -Werror
   SQL preprocessor:     /usr/bin/cpp -traditional-cpp -w -P
  -------------- Additional Info -------------
   Interrupt Tests:   DISABLED use: --with-interrupt-tests to enable
  -------------- Dependencies --------------
   GEOS config:          /usr/bin/geos-config
   GEOS version:         3.5.1
   GDAL config:          /usr/bin/gdal-config
   GDAL version:         2.1.2
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.6.22
   PROJ4 version:        49
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.9.4
   JSON-C support:       yes
   protobuf-c support:   no
   PCRE support:         yes
   Perl:                 /usr/bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
   SFCGAL support:       disabled
   Address Standardizer support:       enabled
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:     /usr/share/xml/docbook/stylesheet/docbook-xsl
   dblatex:              /usr/bin/dblatex
   convert:
   mathml2.dtd:          /usr/share/xml/schema/w3c/mathml/dtd/mathml2.dtd
 configure: WARNING:  --------- GEOS VERSION WARNING ------------
 configure: WARNING:   You are building against GEOS 3.5.1
 configure: WARNING:   To take advantage of all the features of
 configure: WARNING:   this PostGIS version requires GEOS 3.7.0 or higher.
 configure: WARNING:   To take advantage of most of the features of this
 configure: WARNING:   we recommend GEOS 3.6 or higher
 configure: WARNING:   You can download the latest versions from
 configure: WARNING:   http://trac.osgeo.org/geos
 configure: WARNING:
  tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_96_diff)
 --- tickets_expected    2021-08-15 20:50:07.566016528 +0000
 +++ /tmp/pgis_reg/test_96_out   2021-08-15 20:56:01.622589562 +0000
 @@ -345,4 +345,4 @@
  #4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
  #4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
  ERROR:  LWGEOM_addpoint: Invalid offset
 -#4863|t
 +ERROR:  The GEOS version this PostGIS binary was compiled against (35)
 doesn't support 'ST_OrientedEnvelope' function (3.6.0+ required)
 I guess this bug test was put in without considering GEOS version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4969>
