[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.5-18-gd0d82e6
git at osgeo.org
git at osgeo.org
Sun Aug 15 15:09:47 PDT 2021
the project "PostGIS".
The branch, stable-2.5 has been updated
via d0d82e6b16bf2756e49c390d82a7ec80ca69ee5b (commit)
from 1814f8a288b8f4965e4422f283dec926cfeeaccc (commit)
revisions in full, below.
commit d0d82e6b16bf2756e49c390d82a7ec80ca69ee5b
Author: Regina Obe <lr at pcorp.us>
Date: Sun Aug 15 18:09:42 2021 -0400
Move ST_OrientedEnvelope ticket test to oriented_envelope regress as it requires GEOS 3.6+. Closes #4969 for PostGIS 2.5.6
diff --git a/regress/oriented_envelope.sql b/regress/oriented_envelope.sql
index 7029e18..5fc4e27 100644
--- a/regress/oriented_envelope.sql
+++ b/regress/oriented_envelope.sql
@@ -11,3 +11,10 @@ SELECT 't5', ST_Equals('POINT (0.9625 2)', ST_OrientedEnvelope('POINT (0.9625 2)
-- Check using text to avoid precision difference between various GEOS versions
SELECT 't6', ST_AsText(ST_OrientedEnvelope('MULTIPOINT ((0 0), (-1 -1), (3 2))')) = 'POLYGON((3 2,2.88 2.16,-1.12 -0.84,-1 -1,3 2))';
+SELECT '#4863', st_contains(geometry, st_scale(st_orientedenvelope(geometry),
+ 'SRID=3857; POINT(0.8 0.8)', st_centroid(geometry))) from (select
+ 'SRID=3857; POLYGON((-141972.789895508 6755731.24770785,-141935.49511986
+ 6755733.56891884,-141934.403428904 6755716.1146343,-141971.698204552
+ 6755713.77835553,-141972.789895508 6755731.24770785))'::geometry as
+ geometry) x;
diff --git a/regress/oriented_envelope_expected b/regress/oriented_envelope_expected
index 7590cd3..0ac3bc6 100644
--- a/regress/oriented_envelope_expected
+++ b/regress/oriented_envelope_expected
@@ -4,3 +4,4 @@ t3|t
t4|t
t5|t
t6|t
+#4863|t
diff --git a/regress/tickets.sql b/regress/tickets.sql
index 3d7c701..a560c02 100644
--- a/regress/tickets.sql
+++ b/regress/tickets.sql
@@ -1126,10 +1126,3 @@ SELECT '#4670-2', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geomet
SELECT '#4670-3', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 3));
SELECT '#4670-4', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 4));
SELECT '#4670-5', ST_AsEWKT(ST_AddPoint('LINESTRING(0 0, 1 1, 3 3, 4 4)'::geometry, 'POINT(2 2)'::geometry, 5));
-SELECT '#4863', st_contains(geometry, st_scale(st_orientedenvelope(geometry),
- 'SRID=3857; POINT(0.8 0.8)', st_centroid(geometry))) from (select
- 'SRID=3857; POLYGON((-141972.789895508 6755731.24770785,-141935.49511986
- 6755733.56891884,-141934.403428904 6755716.1146343,-141971.698204552
- 6755713.77835553,-141972.789895508 6755731.24770785))'::geometry as
- geometry) x;
diff --git a/regress/tickets_expected b/regress/tickets_expected
index 96372d5..cf76f6f 100644
--- a/regress/tickets_expected
+++ b/regress/tickets_expected
@@ -345,4 +345,3 @@ NOTICE: table "bug_4144_table" does not exist, skipping
#4670-3|LINESTRING(0 0,1 1,3 3,2 2,4 4)
#4670-4|LINESTRING(0 0,1 1,3 3,4 4,2 2)
ERROR: LWGEOM_addpoint: Invalid offset
-#4863|t
Summary of changes:
regress/oriented_envelope.sql | 7 +++++++
regress/oriented_envelope_expected | 1 +
regress/tickets.sql | 7 -------
regress/tickets_expected | 1 -
4 files changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
