[postgis-tickets] [PostGIS] #4971: CUnit compile failures on 2.4 and 2.5
PostGIS trac at osgeo.org
Sun Aug 15 16:16:22 PDT 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.4.10
Component:  postgis  |    Version:  2.5.x
 Keywords:           |
 Both the bessie32 and debbie are failing on testing PostGIS 2.5 branch.
 I'm guessing maybe they are running with newer CUnit and maybe there was a
 patch we added in 3.0 and up to deal with this.
 It's too bad we don't list the CUnit version anywhere.
 Anyway both shows this message over and over again
 19:07:31 checking CUnit/CUnit.h usability... yes
 19:07:31 checking CUnit/CUnit.h presence... yes
 19:07:31 checking for CUnit/CUnit.h... yes
 19:07:31 checking for CU_initialize_registry in -lcunit... yes
 19:11:30 /usr/local/bin/ld:
 cu_bytebuffer.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 multiple definition of `cu_error_msg';
 cu_algorithm.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 first defined here
 cu_buildarea.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 first defined here
 cu_clean.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 first defined here
 cu_print.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 first defined here
 19:11:31 /usr/local/bin/ld:
 cu_minimum_bounding_circle.o:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/447e6ee9ab961d6d5566699b2a880a66b6eaf609/liblwgeom/cunit/cu_tester.h:20:
 first defined here
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4971>
