[postgis-tickets] [PostGIS] #4973: ST_AsMVT returns broken tiles when column name and JSONB key are the same
trac at osgeo.org
Mon Aug 16 06:15:27 PDT 2021
Reporter: emreisikligil | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 3.1.4
Component: postgis | Version: 3.1.x
Keywords: ST_AsMVT |
ST_AsMVT can encode row columns as feature attributes as well as keys and
values in a JSONB column in the row data. It cannot handle the case where
JSONB object contains a key with the name of a column properly. Returned
MVT is formatted properly but some feature attributes are missing or
shifted (values assigned to wrong keys).
The following query can be used to reproduce the issue. Please note that
`field1` exists as a column and a key in the JSONB column.
WITH my_data AS (
SELECT ST_AsMVTGeom(
ST_GeomFromText('POLYGON ((0 0, 10 0, 10 5, 0 -5, 0 0))'),
ST_MakeBox2D(ST_Point(0, 0), ST_Point(4096, 4096)),
4096, 0, false
) AS geometry, 'ffffffffffffffffffff' AS id, 'value1' AS field1,
'{"field1":"value1", "field2":"value2", "field3":"value3",
"field4":"value4", "field5":"value5", "_field6":"value6",
"_field7":"_value7", "_field8":"_value8"}'::JSONB
) SELECT ST_AsMVT(q,'my_layer',4096,'geometry') AS data
FROM (SELECT * FROM my_data) AS q
This query encodes feature attributes as follows.
VectorTileFeature {
properties:{
field1: 'value1',
undefined: undefined,
field2: 'value2',
field4: 'value4',
field5: 'value5',
_field6: 'value6',
_field8: '_value8'
_keys: [
'id',
'field1',
'field2',
'field3',
'field4',
'field5',
'_field6',
'_field7',
'_field8'
_values: [
'ffffffffffffffffffff',
'value1',
'value2',
'value3',
'value4',
'value5',
'value6',
'_value7',
'_value8'
As it can be seen from the result, although all keys and values exist in
the resulting data, attributes are not encoded properly (`_field7` and
`field3` missing). I also came across where attributes are shifted (wrong
values are assigned to keys) but could not reproduce the issue with this
query.
In my opinion, either JSONB or row columns should have the higher
precedence and overwrite the other. And, this information should be
documented in the related docs.
Version:
POSTGIS="3.1.1 0" [EXTENSION] PGSQL="120" GEOS="3.8.1-CAPI-1.13.3"
PROJ="7.1.1" LIBXML="2.9.10" LIBJSON="0.15" LIBPROTOBUF="1.3.3"
WAGYU="0.5.0 (Internal)" TOPOLOGY
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4973>
