[postgis-tickets] [PostGIS] #4970: GEOS 3.9 regress failures on PostGIS 2.5
trac at osgeo.org
Wed Aug 18 16:15:34 PDT 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.5.6
Component: postgis | Version: 2.5.x
Resolution: wontfix | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
Okay you are for the screw it group. Let's quietly close this before strk
notices :)
I can stop testing 2.5 on FreeBSD then. Given the speed at which FreeBSD
EOL's there versions and jump at upgrading GEOS (yikes I can't get a lower
GEOS if I wanted to probably and too lazy to compile my own on FreeBSD).
Running with a PostGIS 2.5 is probably not supported on newer versions
anyway.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4970#comment:2>
