[postgis-tickets] [PostGIS] #4770: [raster] Calling st_union() with WINDOW PARTITION crashes server
trac at osgeo.org
Thu Aug 19 14:30:57 PDT 2021
Reporter: Robins | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.4
Component: raster | Version: 3.0.x
Resolution: | Keywords: st_union
Comment (by pramsey):
The problem appears to be the finalfn freeing the aggregate state object.
When I add a pfree(state) to the (working) st_union(geometry) aggregate, I
can induce the same crashes. Similarly when I remove the pfree from the
raster finalfn, the crashes go away.
The only concern I have about applying the fix over the various known
cases is that I don't understand the mechanism behind leaving the state
object intact... Magic Occurs! As far as I can tell, it's the correct
magic, since the windowed results for the geometry union SEEM correct?
WITH w AS (
SELECT
ST_Union(g) OVER (PARTITION BY b ORDER BY a) AS g
FROM (VALUES ('POINT(0 0)'::geometry, 'A0006', 300), ('POINT(1
1)'::geometry, 'A0006', 302)) t(g, a, b)
SELECT ST_AsText(g) FROM w;
st_astext
POINT(0 0)
POINT(1 1)
or with the partition wider...
WITH w AS (
SELECT
ST_Union(g) OVER (PARTITION BY a ORDER BY b) AS g
st_astext
POINT(0 0)
MULTIPOINT(0 0,1 1)
I'm hampered by not being 100% sure that the expected windowed results are
from ST_Union(geometry) with PARTITION BY and ORDER BY are.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4770#comment:9>
