[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-405-g5272174
git at osgeo.org
git at osgeo.org
Fri Aug 20 10:30:36 PDT 2021
the project "PostGIS".
via 5272174764c2d8c304612c85ef33d3dcf758682d (commit)
from 3e8959ada58400905afa51a45ba052abf29be447 (commit)
revisions in full, below.
commit 5272174764c2d8c304612c85ef33d3dcf758682d
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Aug 20 10:30:32 2021 -0700
Improve doc for ST_Azimuth
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index f918a44..223a21b 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -139,25 +139,27 @@ from somegeogtable;</programlisting>
<refsection>
<title>Description</title>
- <para>Returns the azimuth in radians of the segment defined by the given
- point geometries, or NULL if the two points are coincident. The azimuth is angle is referenced from north, and is positive clockwise: North = 0; East = π/2; South = π; West = 3π/2.</para>
- <para>For the geography type, the forward azimuth is solved as part of the inverse geodesic problem.</para>
- <para>The azimuth is mathematical concept defined as the angle between a reference plane and a point, with angular units in radians.
- Units can be converted to degrees using a built-in PostgreSQL function degrees(), as shown in the example.</para>
+ <para>Returns the azimuth in radians of the line segment defined by the given
+ point geometries, or NULL if the two points are coincident. The azimuth angle is referenced from north (the positive Y axis), and is positive clockwise: North = 0; East = π/2; South = π; West = 3π/2.</para>
+ <para>For the geography type, the azimuth solution is known as the
+ <ulink url="https://en.wikipedia.org/wiki/Geodesics_on_an_ellipsoid">inverse geodesic problem</ulink>.</para>
+ <para>The azimuth is a mathematical concept defined as the angle between a reference plane and a point, with angular units in radians.
+ The result value in radians can be converted to degrees using the PostgreSQL function <varname>degrees()</varname>.</para>
+ <para>Azimuth can be used in conjunction with <xref linkend="ST_Translate" /> to shift an object along its perpendicular axis. See
+ the <varname>upgis_lineshift()</varname> function in the <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctions">PostGIS wiki</ulink> for an implementation of this.</para>
<para>Availability: 1.1.0</para>
<para>Enhanced: 2.0.0 support for geography was introduced.</para>
<para>Enhanced: 2.2.0 measurement on spheroid performed with GeographicLib for improved accuracy and robustness. Requires Proj >= 4.9.0 to take advantage of the new feature.</para>
- <para>Azimuth is especially useful in conjunction with ST_Translate for shifting an object along its perpendicular axis. See
- upgis_lineshift <ulink url="http://trac.osgeo.org/postgis/wiki/UsersWikiplpgsqlfunctions">Plpgsqlfunctions PostGIS wiki section</ulink> for example of this.</para>
</refsection>
<refsection>
<title>Examples</title>
<para>Geometry Azimuth in degrees </para>
<programlisting>
-SELECT degrees(ST_Azimuth(ST_Point(25, 45), ST_Point(75, 100))) AS degA_B,
- degrees(ST_Azimuth(ST_Point(75, 100), ST_Point(25, 45))) AS degB_A;
+SELECT degrees(ST_Azimuth( ST_Point(25, 45), ST_Point(75, 100))) AS degA_B,
+ degrees(ST_Azimuth( ST_Point(75, 100), ST_Point(25, 45) )) AS degB_A;
dega_b | degb_a
@@ -192,7 +194,7 @@ SELECT degrees(ST_Azimuth(ST_Point(25, 45), ST_Point(75, 100))) AS degA_B,
</refsection>
<refsection>
<title>See Also</title>
- <para><xref linkend="ST_Point" />, <xref linkend="ST_Translate" />, <xref linkend="ST_Project" />, <ulink url="http://www.postgresql.org/docs/current/interactive/functions-math.html">PostgreSQL Math Functions</ulink></para>
+ <para><xref linkend="ST_Angle" />, <xref linkend="ST_Point" />, <xref linkend="ST_Translate" />, <xref linkend="ST_Project" />, <ulink url="http://www.postgresql.org/docs/current/interactive/functions-math.html">PostgreSQL Math Functions</ulink></para>
</refsection>
</refentry>
@@ -237,7 +239,7 @@ SELECT degrees(ST_Azimuth(ST_Point(25, 45), ST_Point(75, 100))) AS degA_B,
defined by the start and end points of the input lines
</para>
- <para>The result is a positive angle between 0 and 2*Pi radians.
+ <para>The result is a positive angle between 0 and 2π radians.
The radian result can be converted to degrees using the PostgreSQL function <varname>degrees()</varname>.
</para>
<para>Note that <varname>ST_Angle(P1,P2,P3) = ST_Angle(P2,P1,P2,P3)</varname>.</para>
Summary of changes:
doc/reference_measure.xml | 24 +++++++++++++-----------
1 file changed, 13 insertions(+), 11 deletions(-)
hooks/post-receive
