[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-408-gf6def67
Fri Aug 20 11:29:36 PDT 2021
the project "PostGIS".
       via  f6def67654c25d812446239036cee44812613748 (commit)
      from  1c03eb65188d33db061d7d9d91243d0e6e848022 (commit)
revisions in full, below.
commit f6def67654c25d812446239036cee44812613748
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Aug 20 14:29:32 2021 -0400
    Fix variant description only 2 variants
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index c59ae82..abf7125 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -227,9 +227,8 @@ SELECT degrees(ST_Azimuth( ST_Point(25, 45),  ST_Point(75, 100))) AS degA_B,
 			<para> Computes the clockwise angle between two vectors.
 			</para>
-        <para><emphasis role="bold">Variant 1:</emphasis> computes the angle enclosed by the points P1-P2-P3</para>
-		<para><emphasis role="bold">Variant 2:</emphasis> computes the angle between two vectors defined by points P1-P2 and P3-P4</para>
-		<para><emphasis role="bold">Variant 3:</emphasis> computes the angle between two vectors S1-E1 and S2-E2,
+        <para><emphasis role="bold">Variant 1:</emphasis> computes the angle enclosed by the points P1-P2-P3. If a 4th point provided computes the angle points P1-P2 and P3-P4</para>
+		<para><emphasis role="bold">Variant 2:</emphasis> computes the angle between two vectors S1-E1 and S2-E2,
         defined by the start and end points of the input lines
         </para>
Summary of changes:
 doc/reference_measure.xml | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
hooks/post-receive
