[postgis-tickets] [PostGIS] #4977: Can't compile PostGIS 3.2 on windows - breaking on protobuf-c
PostGIS trac at osgeo.org
Fri Aug 20 21:24:57 PDT 2021
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.2.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"86a8a59791431b279e4d6511c96af0d3e45332d5/git" 86a8a59/git]:
 #!CommitTicketReference repository="git"
 revision="86a8a59791431b279e4d6511c96af0d3e45332d5"
 Partially revert #4964 which broke mingw64 building.  Closes #4977
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4977#comment:3>
