[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-416-g529e39e
git at osgeo.org
git at osgeo.org
Sat Aug 21 16:11:11 PDT 2021
the project "PostGIS".
via 529e39e929108a5d7fbd641ab3c2cd490a76008d (commit)
from a7990f671d1a8c4f56e3f0b25a6784c91774555f (commit)
revisions in full, below.
commit 529e39e929108a5d7fbd641ab3c2cd490a76008d
Author: Martin Davis <mtnclimb at gmail.com>
Date: Sat Aug 21 16:11:07 2021 -0700
Fix doc ST_LineSubstring example
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 7ef7a77..b114516 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -406,31 +406,35 @@ SELECT ST_AsText(ST_LineSubstring( 'LINESTRING(25 50, 100 125, 150 190)', 0.333,
<para>
-A query to cut a LineString into sections of length 100 or less.
-It uses <varname>generate_series()</varname> which creates an implicit JOIN LATERAL
+A query to cut a LineString into sections of length 100 or shorter.
+It uses <varname>generate_series()</varname> with a CROSS JOIN LATERAL
to produce the equivalent of a FOR loop.
</para>
<programlisting>
WITH data(id, geom) AS (VALUES
- ( 'a1', 'LINESTRING (0 0, 250 0)'::geometry )
-SELECT id, n, ST_AsText( ST_LineSubstring(geom, n * frac,
- CASE
- WHEN (n+1) * frac < 1 THEN (n+1) * frac
- ELSE 1
- END )) AS geom
-FROM
- (SELECT id, geom, ST_Length(geom) AS len,
- 100.0 / ST_Length(geom) AS frac,
- generate_series(0, floor(ST_Length(geom) / 100.0)::integer ) AS n
- FROM data
- ) AS t;
- id | n | geom
- a1 | 0 | LINESTRING(0 0,100 0)
- a1 | 1 | LINESTRING(100 0,200 0)
- a1 | 2 | LINESTRING(200 0,250 0)
+ ( 'A', 'LINESTRING( 0 0, 200 0)'::geometry ),
+ ( 'B', 'LINESTRING( 0 100, 350 100)'::geometry ),
+ ( 'C', 'LINESTRING( 0 200, 50 200)'::geometry )
+SELECT id, i, ST_AsText( ST_LineSubstring( d.geom, startfrac, LEAST( endfrac, 1 )) ) AS geom
+FROM (SELECT id, geom, ST_Length(geom) len, 100 sublen FROM data) AS d
+CROSS JOIN LATERAL (
+ SELECT i, (sublen * i) / len AS startfrac,
+ (sublen * (i+1)) / len AS endfrac
+ FROM generate_series(0, floor( d.len / sublen )::integer ) AS t(i)
+ -- skip last i if line length is exact multiple of sublen
+ WHERE (sublen * i)/len <> 1.0
+ ) AS d2;
+ id | i | geom
+ A | 0 | LINESTRING(0 0,100 0)
+ A | 1 | LINESTRING(100 0,200 0)
+ B | 0 | LINESTRING(0 100,100 100)
+ B | 1 | LINESTRING(100 100,200 100)
+ B | 2 | LINESTRING(200 100,300 100)
+ B | 3 | LINESTRING(300 100,350 100)
+ C | 0 | LINESTRING(0 200,50 200)
</programlisting>
</refsection>
Summary of changes:
doc/reference_lrs.xml | 46 +++++++++++++++++++++++++---------------------
1 file changed, 25 insertions(+), 21 deletions(-)
hooks/post-receive
