[postgis-tickets] [PostGIS] #4980: PostGIS 2.4 and 2.5 address_standardizer on windows won't compile anymore
trac at osgeo.org
Sat Aug 21 18:24:38 PDT 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.10
Component: pagc_address_parser | Version: 2.4.x
Keywords: |
Sadly I'm still having issue on winnie with address_standardizer compiling
on 2.4 and 2.5. The PostGIS 3 series is fine.
C compiler: x86_64-w64-mingw32-gcc -Wall -fno-omit-frame-
pointer
SQL preprocessor: /mingw/bin/cpp -traditional-cpp -w -P
-------------- Additional Info -------------
Interrupt Tests: DISABLED use: --with-interrupt-tests to enable
-------------- Dependencies --------------
GEOS config: /projects/geos/rel-3.8.1w64gcc81/bin/geos-config
GEOS version: 3.8.1
GDAL config: /projects/gdal/rel-2.4.4w64gcc81/bin/gdal-config
GDAL version: 2.4.4
SFCGAL config: /projects/CGAL/rel-sfcgal-1.3.8w64gcc81/bin
/sfcgal-config
SFCGAL version: 1.3.8
PostgreSQL config:
/projects/postgresql/rel/pg10w64gcc81/bin/pg_config
PostgreSQL version: PostgreSQL 10.15
PROJ4 version: 52
Libxml2 config: /projects/libxml/rel-
libxml2-2.7.8w64gcc81/bin/xml2-config
Libxml2 version: 2.9.9
JSON-C support: yes
protobuf-c support: yes
protobuf-c version: 1002001
PCRE support: yes
Perl: /bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: enabled
Address Standardizer support: enabled
-------- Documentation Generation --------
libxml2-2.9.9w64gcc81/include -I./src/include/port/win32 -DEXEC_BACKEND
-I/projects/libxml/rel-libxml2-2.9.9w64gcc81/include/libxml2
-IE:/jenkins/postgresql/rel/pg10w64gcc81/include/server/port/win32
-DWIN32_STACK_RLIMIT=4194304 -c -o pagc_tools.o pagc_tools.c
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Wendif-labels -Wmissing-format-attribute -Wformat-security
-fno-strict-aliasing -fwrapv -fexcess-precision=standard -Wno-format-
truncation -Wno-stringop-truncation -g -O2 -Wall -fno-omit-frame-pointer
-IE:/jenkins/geos/rel-3.8.1w64gcc81/include
-I/projects/proj/rel-5.2.0w64gcc81/include
-DACCEPT_USE_OF_DEPRECATED_PROJ_API_H=1
-I/projects/protobuf/rel-3.2.0w64gcc81/include -I/projects/libxml/rel-
libxml2-2.7.8w64gcc81/include/libxml2 -I/projects/CGAL/rel-
sfcgal-1.3.8w64gcc81/include -DHAVE_SFCGAL
-I/projects/json-c/rel-0.12w64gcc81/include
-I/projects/pcre/rel-8.33w64gcc81/include
-I/projects/postgresql/rel/pg10w64gcc81/include -I/projects/rel-
libiconv-1.13.1w64gcc81/include -I. -I./
-IE:/jenkins/postgresql/rel/pg10w64gcc81/include/internal
-I/projects/zlib/rel-zlib-1.2.11w64gcc81/include -I/projects/libxml/rel-
-DWIN32_STACK_RLIMIT=4194304 -c -o parseaddress-api.o parseaddress-api.c
-DWIN32_STACK_RLIMIT=4194304 -c -o standard.o standard.c
during RTL pass: final
standard.c: In function 'std_standardize':
standard.c:535:1: internal compiler error: in based_loc_descr, at
dwarf2out.c:14264
libbacktrace could not find executable to open
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://sourceforge.net/projects/mingw-w64> for instructions.
make[2]: *** [<builtin>: standard.o] Error 1
make[2]: Leaving directory
'/projects/postgis/branches/2.4/extensions/address_standardizer'
make[1]: *** [Makefile:26: all] Error 1
make[1]: Leaving directory '/projects/postgis/branches/2.4/extensions'
make: *** [GNUmakefile:16: all] Error 1
I'm not sure how long it's been broken since I haven't shipped 2.4 and 2.5
in quite sometime, preferring to ship the newer PostGIS even for older
PostgreSQL.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4980>
