[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-418-g7a4f76d
Sun Aug 22 10:53:05 PDT 2021
the project "PostGIS".
       via  7a4f76ddfc74e9f9af468a710103e1ce08a6cda9 (commit)
      from  89e3ce9ac5f9832aa24e19ac687b3f8a993d1119 (commit)
revisions in full, below.
commit 7a4f76ddfc74e9f9af468a710103e1ce08a6cda9
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Sun Aug 22 10:52:59 2021 -0700
    Minor fix to doc ST_LIneSubstring example
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index b9755cc..a499d65 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -416,14 +416,17 @@ WITH data(id, geom) AS (VALUES
         ( 'B', 'LINESTRING( 0 100, 350 100)'::geometry ),
         ( 'C', 'LINESTRING( 0 200, 50 200)'::geometry )
-SELECT id, i, ST_AsText( ST_LineSubstring( d.geom, startfrac, LEAST( endfrac, 1 )) ) AS geom
-FROM (SELECT id, geom, ST_Length(geom) len, 100 sublen FROM data) AS d
+SELECT id, i,
+       ST_AsText( ST_LineSubstring( geom, startfrac, LEAST( endfrac, 1 )) ) AS geom
+FROM (
+    SELECT id, geom, ST_Length(geom) len, 100 sublen FROM data
+    ) AS d
 CROSS JOIN LATERAL (
     SELECT i, (sublen * i) / len AS startfrac,
               (sublen * (i+1)) / len AS endfrac
-        FROM generate_series(0, floor( d.len / sublen )::integer ) AS t(i)
-        -- skip last i if line length is exact multiple of sublen
-        WHERE (sublen * i)/len <> 1.0
+    FROM generate_series(0, floor( len / sublen )::integer ) AS t(i)
+    -- skip last i if line length is exact multiple of sublen
+    WHERE (sublen * i) / len <> 1.0
     ) AS d2;
  id | i |            geom
Summary of changes:
 doc/reference_lrs.xml | 13 ++++++++-----
 1 file changed, 8 insertions(+), 5 deletions(-)
hooks/post-receive
