[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-431-ga9382ae
git at osgeo.org
git at osgeo.org
Wed Aug 25 10:56:23 PDT 2021
the project "PostGIS".
via a9382ae7fdbcbe9666cad0c0303991f3049865b5 (commit)
from d02637045e019c810cf0aeac3d95f3d255eff05f (commit)
revisions in full, below.
commit a9382ae7fdbcbe9666cad0c0303991f3049865b5
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Aug 25 10:56:07 2021 -0700
Include srs in GeoJSON where it exists in spatial_ref_sys, closes #4799
diff --git a/NEWS b/NEWS
index d54da55..4b3c98b 100644
--- a/NEWS
+++ b/NEWS
@@ -46,6 +46,7 @@ PostGIS 3.2.0
(Jan Katins of Aiven, Regina Obe)
- #4975, PostGIS upgrade change to not use temp tables (Jan Katins of Aiven)
- #4981, ST_StartPoint support any geometry (Aliaksandr Kalenik)
+ - #4799, Include srs in GeoJSON where it exists in spatial_ref_sys.
* New features*
diff --git a/postgis/lwgeom_export.c b/postgis/lwgeom_export.c
index 82fa86a..4d09512 100644
--- a/postgis/lwgeom_export.c
+++ b/postgis/lwgeom_export.c
@@ -267,7 +267,14 @@ Datum geometry_to_json(PG_FUNCTION_ARGS)
GSERIALIZED *geom = PG_GETARG_GSERIALIZED_P(0);
LWGEOM *lwgeom = lwgeom_from_gserialized(geom);
- lwvarlena_t *geojson = lwgeom_to_geojson(lwgeom, NULL, 15, 0);
+ const char *srs = NULL;
+ lwvarlena_t *geojson;
+ if (lwgeom->srid != SRID_UNKNOWN)
+ const int short_crs = LW_TRUE;
+ srs = GetSRSCacheBySRID(fcinfo, lwgeom->srid, short_crs);
+ geojson = lwgeom_to_geojson(lwgeom, srs, 15, 0);
lwgeom_free(lwgeom);
PG_FREE_IF_COPY(geom, 0);
PG_RETURN_TEXT_P(geojson);
@@ -278,7 +285,14 @@ Datum geometry_to_jsonb(PG_FUNCTION_ARGS)
PG_RETURN_DATUM(DirectFunctionCall1(jsonb_in, PointerGetDatum(pstrdup(geojson->data))));
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index a84404f..72c597b 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1390,10 +1390,7 @@ SELECT '#4949', 'Arctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Trans
SELECT '#4949', 'Antarctic Stereographic forward', ST_AsEWKT(ST_SnapToGrid(ST_Transform(
'SRID=4326;POINT(-36.75 -54.25)'::geometry, 3031),0.1));
-- #4916, #4770, #4724, #4916, #4940
SELECT '#4770.a',
ST_Union(NULL::geometry) OVER (ORDER BY b)
FROM (VALUES ('A0006', 300),
@@ -1416,7 +1413,17 @@ WITH w AS (
('POINT(1 1)'::geometry, 'A0006', 302)) t(g, a, b)
SELECT '#4770.c', ST_AsText(g), s FROM w;
+-- https://trac.osgeo.org/postgis/ticket/4799
+SELECT
+ '#4799', ST_AsGeoJSON(data.*, geom_column => 'geom2', maxdecimaldigits => 3)
+FROM
+ (SELECT
+ 1 AS id,
+ ST_SnapToGrid(ST_Transform(geom, 3035), 1) geom1,
+ ST_SnapToGrid(ST_Transform(geom, 25832), 1) geom2
+ FROM
+ ST_SetSRID(ST_MakePoint(7, 51), 4326) geom
+ ) data;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index af581a8..2a3cb68 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -458,3 +458,4 @@ ERROR: LWGEOM_addpoint: Invalid offset
#4770.b|POINT(1 1)|302
#4770.c|POINT(0 0)|300
#4770.c|MULTIPOINT(0 0,1 1)|602
+#4799|{"type": "Feature", "geometry": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:25832"}},"coordinates":[359667,5651729]}, "properties": {"id": 1, "geom1": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:3035"}},"coordinates":[4110471,3103061]}}}
Summary of changes:
NEWS | 1 +
postgis/lwgeom_export.c | 18 ++++++++++++++++--
regress/core/tickets.sql | 15 +++++++++++----
regress/core/tickets_expected | 1 +
4 files changed, 29 insertions(+), 6 deletions(-)
hooks/post-receive
