[postgis-tickets] [PostGIS] #4878: check_tests_enabled files in parallel make
PostGIS trac at osgeo.org
Wed Aug 25 11:39:06 PDT 2021
  Reporter:  pramsey     |      Owner:  strk
      Type:  defect      |     Status:  closed
  Priority:  high        |  Milestone:  PostGIS 3.2.0
 Component:  postgis     |    Version:  master
Resolution:  worksforme  |   Keywords:
Changes (by pramsey):
 * status:  assigned => closed
 * resolution:   => worksforme
Comment:
 Not sure if something changed, but I cannot dupe.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4878#comment:1>
